iPad 4 CDMA Front Panel Assembly Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPad 4 CDMA Front Panel Assembly Replacement, Front Panel Assembly: step 1, image 1 of 2 iPad 4 CDMA Front Panel Assembly Replacement, Front Panel Assembly: step 1, image 2 of 2
    • Remove the four 2 mm Phillips #00 screws securing the LCD to the aluminum frame.
    • The bottom left screw is obscured by the home button ribbon cable connector. Carefully move the home button ribbon cable aside to remove the bottom left screw.
  2. iPad 4 CDMA Front Panel Assembly Replacement: step 2, image 1 of 3 iPad 4 CDMA Front Panel Assembly Replacement: step 2, image 2 of 3 iPad 4 CDMA Front Panel Assembly Replacement: step 2, image 3 of 3
    • Using a plastic opening tool or a spudger, lift the right edge of the LCD out of the iPad.
    • Rotate the LCD along its left edge and lay it down on top of the front glass panel.
    • Be careful as you move the LCD. The ribbon cable is fragile and may break if it is flexed too much.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 8
All Time: 115
