iPad 3 Wi-Fi Headphone Jack Assembly Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPad 3 Wi-Fi Headphone Jack Assembly Replacement, Headphone Jack Assembly: step 1, image 1 of 2 iPad 3 Wi-Fi Headphone Jack Assembly Replacement, Headphone Jack Assembly: step 1, image 2 of 2
    • Peel back and remove the adhesive tape covering the headphone jack assembly.
  2. iPad 3 Wi-Fi Headphone Jack Assembly Replacement: step 2, image 1 of 3 iPad 3 Wi-Fi Headphone Jack Assembly Replacement: step 2, image 2 of 3 iPad 3 Wi-Fi Headphone Jack Assembly Replacement: step 2, image 3 of 3
    • Using the flat end of a spudger, pry the front-facing camera connector off of its socket on the headphone jack assembly.
    • Slide the spudger to the right, releasing the adhesive holding down the camera cable.
  3. iPad 3 Wi-Fi Headphone Jack Assembly Replacement: step 3, image 1 of 2 iPad 3 Wi-Fi Headphone Jack Assembly Replacement: step 3, image 2 of 2
    • Using the tip of a spudger, flip up the retaining flap on the microphone cable ZIF connector.
  4. iPad 3 Wi-Fi Headphone Jack Assembly Replacement: step 4, image 1 of 2 iPad 3 Wi-Fi Headphone Jack Assembly Replacement: step 4, image 2 of 2
    • Insert the tip of the spudger underneath the microphone ribbon cable, removing it from its ZIF connector.
    • Slide the spudger to the left, releasing the adhesive holding the microphone ribbon cable to the headphone jack assembly.
  5. iPad 3 Wi-Fi Headphone Jack Assembly Replacement: step 5, image 1 of 2 iPad 3 Wi-Fi Headphone Jack Assembly Replacement: step 5, image 2 of 2
    • Flip up the retaining flap securing the volume/power button ribbon cable connector to the headphone jack assembly board.
    • Remove the volume button ribbon cable from its ZIF connector.
  6. iPad 3 Wi-Fi Headphone Jack Assembly Replacement: step 6, image 1 of 3 iPad 3 Wi-Fi Headphone Jack Assembly Replacement: step 6, image 2 of 3 iPad 3 Wi-Fi Headphone Jack Assembly Replacement: step 6, image 3 of 3
    • Remove the following screws from the headphone jack assembly:
    • Five 2.6 mm Phillips #0
    • Two 2.0 mm Wide Head Phillips #00
    • Two 2.6 mm Phillips #00
    • These screws are angled into the aluminum frame. Be sure to hold the screwdriver so that the screwdriver is in line with the screw, to avoid stripping the screw.
  7. iPad 3 Wi-Fi Headphone Jack Assembly Replacement: step 7, image 1 of 2 iPad 3 Wi-Fi Headphone Jack Assembly Replacement: step 7, image 2 of 2
    • Gently peel the headphone jack assembly ribbon cable up from the foam pad in the top left of the rear case.
    • If necessary, use the flat end of a spudger to loosen the adhesive securing the ribbon cable to the foam.
  8. iPad 3 Wi-Fi Headphone Jack Assembly Replacement: step 8, image 1 of 2 iPad 3 Wi-Fi Headphone Jack Assembly Replacement: step 8, image 2 of 2
    • Grasping the headphone jack assembly with both hands, pull the assembly from the iPad, minding any cables that may get caught.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 99
