iPad 10 Battery Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. iPad 10 Battery Removal, Remove the battery connector screw: step 1, image 1 of 1
      • Use a JIS 00 screwdriver to remove the 1.7 mm‑long screw securing the battery connector.
      Ask FixBot
    2. iPad 10 Battery Removal, Remove the battery adhesive: step 2, image 1 of 3 iPad 10 Battery Removal, Remove the battery adhesive: step 2, image 2 of 3 iPad 10 Battery Removal, Remove the battery adhesive: step 2, image 3 of 3
      • Use a pair of blunt tweezers to grab one of the four stretch-release adhesive strips under the battery.
      Ask FixBot
    3. iPad 10 Battery Removal: step 3, image 1 of 2 iPad 10 Battery Removal: step 3, image 2 of 2
      • Pull the adhesive pull tab away from the battery, and roll the tweezers to wrap the adhesive around them.
      Ask FixBot
    4. iPad 10 Battery Removal: step 4, image 1 of 3 iPad 10 Battery Removal: step 4, image 2 of 3 iPad 10 Battery Removal: step 4, image 3 of 3
      • Slowly pull the adhesive out, keeping it as close to the iPad as possible without touching it.
      Ask FixBot
    5. iPad 10 Battery Removal, Remove the remaining stretch‑release strips: step 5, image 1 of 3 iPad 10 Battery Removal, Remove the remaining stretch‑release strips: step 5, image 2 of 3 iPad 10 Battery Removal, Remove the remaining stretch‑release strips: step 5, image 3 of 3
      • Remove the remaining three stretch‑release adhesive strips securing the battery.
      Ask FixBot
    6. iPad 10 Battery Removal, Lift the battery cells: step 6, image 1 of 3 iPad 10 Battery Removal, Lift the battery cells: step 6, image 2 of 3 iPad 10 Battery Removal, Lift the battery cells: step 6, image 3 of 3
      • Insert a plastic card beneath each battery cell to separate any remaining adhesive securing it.
      • Don't bend or crease the battery. If the battery won't lift, apply a few drops of high-concentration (>90%) isopropyl alcohol or adhesive remover so it runs underneath the stuck section.
      Ask FixBot
    7. iPad 10 Battery Removal, Remove the battery: step 7, image 1 of 3 iPad 10 Battery Removal, Remove the battery: step 7, image 2 of 3 iPad 10 Battery Removal, Remove the battery: step 7, image 3 of 3
      • Slide the battery away from the logic board to disconnect its connector.
      • If it doesn't slide out easily, "walk" the battery out, first on the left side, then the right, to disconnect it.
      • Remove the battery.
      Ask FixBot
Finish Line
Nick Schultz
65,246 Reputation
343 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 35
