How to Remove Battery Acid From a 2005-2009 Ford Mustang Battery
Views: 2.4K
View statistics:
Past 24 Hours:
6
Past 7 Days:
26
Past 30 Days:
117
All Time:
2,438
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide will show you how to safely remove corrosion from a 2005-2009 Ford Mustang battery.
Before you begin, the following are highly recommended:
  • Protective Eyewear
  • Protective Face Coverings
    1. How to Remove Battery Acid From a 2005-2009 Ford Mustang Battery, Locate the Battery: step 1, image 1 of 3 How to Remove Battery Acid From a 2005-2009 Ford Mustang Battery, Locate the Battery: step 1, image 2 of 3 How to Remove Battery Acid From a 2005-2009 Ford Mustang Battery, Locate the Battery: step 1, image 3 of 3
      • Open the hood and prop it open using the hood prop.
      • Locate the battery.
      • Battery acid can cause skin corrosion. Wear protective face coverings, eyewear and gloves to prevent skin contact.
      Ask FixBot
    2. How to Remove Battery Acid From a 2005-2009 Ford Mustang Battery, Disconnect the Terminals: step 2, image 1 of 3 How to Remove Battery Acid From a 2005-2009 Ford Mustang Battery, Disconnect the Terminals: step 2, image 2 of 3 How to Remove Battery Acid From a 2005-2009 Ford Mustang Battery, Disconnect the Terminals: step 2, image 3 of 3
      • Using the 8-mm socket wrench, disconnect the battery terminals.
      • Disconnecting the terminals in the wrong order can damage the battery.
      • Disconnect the negative terminal first.
      • Disconnect the positive terminal second.
      • Keep the negative terminal far away from the battery post once it is disconnected to prevent battery damage.
      Ask FixBot
    3. How to Remove Battery Acid From a 2005-2009 Ford Mustang Battery, Remove the Battery: step 3, image 1 of 1
      • Remove the battery and place it onto a disposable rag.
      Ask FixBot
    4. How to Remove Battery Acid From a 2005-2009 Ford Mustang Battery, Remove the Battery Dust: step 4, image 1 of 3 How to Remove Battery Acid From a 2005-2009 Ford Mustang Battery, Remove the Battery Dust: step 4, image 2 of 3 How to Remove Battery Acid From a 2005-2009 Ford Mustang Battery, Remove the Battery Dust: step 4, image 3 of 3
      • Scrub inside and around the terminals using the battery brush.
      • Scrub until the dust is gone, or flush with the terminal.
      • Inhaling battery dust is harmful to your lungs.
      Ask FixBot
    5. How to Remove Battery Acid From a 2005-2009 Ford Mustang Battery, Spray the Terminals: step 5, image 1 of 2 How to Remove Battery Acid From a 2005-2009 Ford Mustang Battery, Spray the Terminals: step 5, image 2 of 2
      • Spray the terminals with the acid detector spray.
      • Wait for the spray to change colors.
      Ask FixBot
    6. How to Remove Battery Acid From a 2005-2009 Ford Mustang Battery, Rinse the Battery Box and Terminals: step 6, image 1 of 2 How to Remove Battery Acid From a 2005-2009 Ford Mustang Battery, Rinse the Battery Box and Terminals: step 6, image 2 of 2
      • Pour warm water onto the terminals and into the battery box.
      • Repeat steps 5-6 until the corrosion is no longer visible.
      Ask FixBot
    7. How to Remove Battery Acid From a 2005-2009 Ford Mustang Battery, Dry the Battery Box and Terminals: step 7, image 1 of 1
      • Dry the battery box and terminals using another disposable rag.
      Ask FixBot
    8. How to Remove Battery Acid From a 2005-2009 Ford Mustang Battery, Clean the Terminal Posts: step 8, image 1 of 3 How to Remove Battery Acid From a 2005-2009 Ford Mustang Battery, Clean the Terminal Posts: step 8, image 2 of 3 How to Remove Battery Acid From a 2005-2009 Ford Mustang Battery, Clean the Terminal Posts: step 8, image 3 of 3
      • Remove the previous washers.
      • Scrub the battery terminal posts using the battery brush.
      • Scratching the battery can cause leaks and more corrosion.
      Ask FixBot
    9. How to Remove Battery Acid From a 2005-2009 Ford Mustang Battery, Apply the Terminal Cleaner: step 9, image 1 of 3 How to Remove Battery Acid From a 2005-2009 Ford Mustang Battery, Apply the Terminal Cleaner: step 9, image 2 of 3 How to Remove Battery Acid From a 2005-2009 Ford Mustang Battery, Apply the Terminal Cleaner: step 9, image 3 of 3
      • Spray the terminal posts with the acid detector spray.
      • Wipe the spray off once it changes colors.
      • If there is no color change after a minute, wipe off the spray.
      Ask FixBot
    10. How to Remove Battery Acid From a 2005-2009 Ford Mustang Battery, Dry the Terminal Posts: step 10, image 1 of 1
      • Dry the terminal posts completely.
      Ask FixBot
    11. How to Remove Battery Acid From a 2005-2009 Ford Mustang Battery, Apply the Battery Protect Spray: step 11, image 1 of 1
      • Spray the terminals with the battery protect spray.
      Ask FixBot
    12. How to Remove Battery Acid From a 2005-2009 Ford Mustang Battery, Apply the Protective Agents: step 12, image 1 of 3 How to Remove Battery Acid From a 2005-2009 Ford Mustang Battery, Apply the Protective Agents: step 12, image 2 of 3 How to Remove Battery Acid From a 2005-2009 Ford Mustang Battery, Apply the Protective Agents: step 12, image 3 of 3
      • Spray the battery protect spray onto the terminal posts.
      • Apply the terminal grease onto the new washers.
      • Place the new washers onto the battery terminal posts.
      Ask FixBot
    13. How to Remove Battery Acid From a 2005-2009 Ford Mustang Battery, Reconnect the Battery: step 13, image 1 of 3 How to Remove Battery Acid From a 2005-2009 Ford Mustang Battery, Reconnect the Battery: step 13, image 2 of 3 How to Remove Battery Acid From a 2005-2009 Ford Mustang Battery, Reconnect the Battery: step 13, image 3 of 3
      • Place the battery back into the battery box.
      • Reconnect the terminals to the battery posts.
      • Reconnecting the terminals in the wrong order can damage the battery.
      • Reconnect the positive terminal first
      • Reconnect the negative terminal second.
      Ask FixBot
    14. How to Remove Battery Acid From a 2005-2009 Ford Mustang Battery, Let the Battery Dry: step 14, image 1 of 1
      • Allow the spray and grease to air-dry for 5-minutes.
      Ask FixBot
Finish Line
Group 5
229 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 26
Past 30 Days: 117
All Time: 2,438
