Shop the Holiday Gift Guide
HP Envy 17m-ae111dx Back Cover Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
3
Past 30 Days:
14
All Time:
140
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 4 - 7 minutes
Difficulty: Easy
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Pre-requisite only guide.
Tools
    1. HP Envy 17m-ae111dx Back Cover Replacement, Back Cover: step 1, image 1 of 1
      • Power off your laptop before beginning disassembly.
      • Place the laptop on its back.
      Ask FixBot
    2. HP Envy 17m-ae111dx Back Cover Replacement: step 2, image 1 of 3 HP Envy 17m-ae111dx Back Cover Replacement: step 2, image 2 of 3 HP Envy 17m-ae111dx Back Cover Replacement: step 2, image 3 of 3
      • Remove the plastic covering to the Disk Reader.
      • Locate the small hole on the side of the disk reader. Insert the T5 Torx head screwdriver (or device of similar thickness) to release the covering for the disk reader.
      • If the button on the side is jammed, pry off the covering by using the iFixit Opening Tool.
      Ask FixBot
    3. HP Envy 17m-ae111dx Back Cover Replacement: step 3, image 1 of 3 HP Envy 17m-ae111dx Back Cover Replacement: step 3, image 2 of 3 HP Envy 17m-ae111dx Back Cover Replacement: step 3, image 3 of 3
      • Unscrew all visible screws.
      • Use the T5 Torx Screwdriver and remove the four visible 6.5mm screws on the bottom of the laptop.
      • One 2.5mm screw, is located where the disk reader was once located. Use a Phillips #00 screwdriver to remove the single screw that connects the bottom cover of the laptop to the bottom frame.
      Ask FixBot
    4. HP Envy 17m-ae111dx Back Cover Replacement: step 4, image 1 of 2 HP Envy 17m-ae111dx Back Cover Replacement: step 4, image 2 of 2
      • Pry the gripper completely off to expose the two screws.
      • Remove the 2.5mm screws under the gripper nearest to the hinge using the Phillips #00 screwdriver.
      Ask FixBot
    5. HP Envy 17m-ae111dx Back Cover Replacement: step 5, image 1 of 3 HP Envy 17m-ae111dx Back Cover Replacement: step 5, image 2 of 3 HP Envy 17m-ae111dx Back Cover Replacement: step 5, image 3 of 3
      • Use the iFixit opening tool to pry off the back cover.
      • Ensure that you go all the way around the laptop with the tool to take it off.
      Ask FixBot
Justin Ogihara
31,734 Reputation
52 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 14
All Time: 140
