Dremel 8220 Collet Replacement
    1. Dremel 8220 Collet Replacement, Collet: step 1, image 1 of 1
      • Press and hold down on the gear lock button to lock the shaft.
      Ask FixBot
    2. Dremel 8220 Collet Replacement: step 2, image 1 of 1
      • With the lock held down, begin unscrewing the collar wrench.
      Ask FixBot
    3. Dremel 8220 Collet Replacement: step 3, image 1 of 1
      • Remove the collet nut, and poke out the collet.
      • If the collet is jammed in the collet nut, more force will need to be applied.
      Ask FixBot
For dremel reassembly, follow the guide steps in reverse order.
connor anisko
312 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 35
Past 30 Days: 74
All Time: 2,389
