iMac Intel 27" EMC 2546 Logic Board Assembly Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iMac Intel 27" EMC 2546 Logic Board Assembly Replacement, Logic Board Assembly: step 1, image 1 of 3 iMac Intel 27" EMC 2546 Logic Board Assembly Replacement, Logic Board Assembly: step 1, image 2 of 3 iMac Intel 27" EMC 2546 Logic Board Assembly Replacement, Logic Board Assembly: step 1, image 3 of 3
    • Use the flat end of a spudger to disconnect each of the four antenna connectors from the AirPort/Bluetooth card.
    • Note the original positions for each connector when reconnecting the cables. From left to right on the card, the antennas are connected in the following order:
    • Leftmost
    • Top
    • Upper right
    • Lower right
  2. iMac Intel 27" EMC 2546 Logic Board Assembly Replacement: step 2, image 1 of 3 iMac Intel 27" EMC 2546 Logic Board Assembly Replacement: step 2, image 2 of 3 iMac Intel 27" EMC 2546 Logic Board Assembly Replacement: step 2, image 3 of 3
    • This is a delicate connection that can be easily broken.
    • Flip up the metal retaining bracket on the iSight camera cable.
    • Pull the camera cable connector straight out of its socket, toward the top of the iMac.
  3. iMac Intel 27" EMC 2546 Logic Board Assembly Replacement: step 3, image 1 of 3 iMac Intel 27" EMC 2546 Logic Board Assembly Replacement: step 3, image 2 of 3 iMac Intel 27" EMC 2546 Logic Board Assembly Replacement: step 3, image 3 of 3
    • Use the flat end of a spudger to disconnect the headphone jack cable connector from its socket on the logic board.
    • Gently push the cable out of the way.
  4. iMac Intel 27" EMC 2546 Logic Board Assembly Replacement: step 4, image 1 of 2 iMac Intel 27" EMC 2546 Logic Board Assembly Replacement: step 4, image 2 of 2
    • Remove the following screws from the front of the logic board:
    • Two 23.7 mm T10 screws
    • Four 7.4 mm T10 screws
    • One 20.8 mm T25 spacer screw
    • One captive T10 screw
    • This screw is beneath a hole in the logic board. You'll need a fixed screwdriver or the 60 mm extension from an iFixit driver kit to reach it.
  5. iMac Intel 27" EMC 2546 Logic Board Assembly Replacement: step 5, image 1 of 3 iMac Intel 27" EMC 2546 Logic Board Assembly Replacement: step 5, image 2 of 3 iMac Intel 27" EMC 2546 Logic Board Assembly Replacement: step 5, image 3 of 3
    • The hard drive SATA cable can't be removed just yet, but will get in the way of removing the logic board.
    • Pull the cable and connector through the right hard drive bracket. Move the cable to the right side of the iMac, out of the way of the exhaust port.
  6. iMac Intel 27" EMC 2546 Logic Board Assembly Replacement: step 6, image 1 of 1
    • Remove two 5.7 mm T10 screws from the top of the heat sink exhaust duct.
  7. iMac Intel 27" EMC 2546 Logic Board Assembly Replacement: step 7, image 1 of 3 iMac Intel 27" EMC 2546 Logic Board Assembly Replacement: step 7, image 2 of 3 iMac Intel 27" EMC 2546 Logic Board Assembly Replacement: step 7, image 3 of 3
    • Tilt the logic board slightly forward.
    • Lift the logic board straight up and out of the iMac. Be careful not to snag on any of the screw posts attached to the inside of the rear case.
  8. iMac Intel 27" EMC 2546 Logic Board Assembly Replacement: step 8, image 1 of 2 iMac Intel 27" EMC 2546 Logic Board Assembly Replacement: step 8, image 2 of 2
    • When reassembling your iMac, be very careful to align the exterior I/O ports correctly. The logic board can sit crooked even when secured with all its screws.
    • You can use a USB flashdrive or ethernet cable to ensure the logic board is seated correctly while you screw it in.
Andrew Optimus Goldheart
503,352 Reputation
407 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,430 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 419
