iMac Intel 27" EMC 2309 and 2374 Optical Drive Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iMac Intel 27" EMC 2309 and 2374 Optical Drive Replacement, Optical Drive: step 1, image 1 of 1
    • Remove the four T10 Torx screws securing the optical drive to the outer case.
  2. iMac Intel 27" EMC 2309 and 2374 Optical Drive Replacement: step 2, image 1 of 1
    • Pull the optical drive thermal sensor connector straight away from its socket on the logic board.
  3. iMac Intel 27" EMC 2309 and 2374 Optical Drive Replacement: step 3, image 1 of 2 iMac Intel 27" EMC 2309 and 2374 Optical Drive Replacement: step 3, image 2 of 2
    • Insert a spudger between the optical drive connector and the optical drive.
    • Twist the spudger to slightly separate the optical drive connector from the optical drive, then use your fingers to pull the connector away from the drive.
  4. iMac Intel 27" EMC 2309 and 2374 Optical Drive Replacement: step 4, image 1 of 1
    • Lift the left edge of the optical drive slightly and pull it away from the right side of the outer case.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,154
