iMac Intel 21.5" Retina 4K Display Lower Support Bracket Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iMac Intel 21.5" Retina 4K Display Lower Support Bracket Replacement, Lower Support Bracket: step 1, image 1 of 2 iMac Intel 21.5" Retina 4K Display Lower Support Bracket Replacement, Lower Support Bracket: step 1, image 2 of 2
    • Remove the following five Phillips screws holding the lower support bracket in place:
    • Four 3.2 mm screws
    • One 1.7 mm screw
    • You may need to peel up the display adhesive lining the bottom edge of the iMac enclosure to access the screws.
  2. iMac Intel 21.5" Retina 4K Display Lower Support Bracket Replacement: step 2, image 1 of 1
    • Remove the lower support bracket from the iMac enclosure.
Evan Noronha
223,523 Reputation
168 Guides authored
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 13
All Time: 153
