iMac Intel 21.5" Retina 4K Display Display Assembly Cables Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iMac Intel 21.5" Retina 4K Display Display Assembly Cables Replacement, Display Assembly Cables: step 1, image 1 of 2 iMac Intel 21.5" Retina 4K Display Display Assembly Cables Replacement, Display Assembly Cables: step 1, image 2 of 2
    • Lift the display up enough to have easy access to the connector, but not so much that you stretch the cables and stress their connections (about 8").
    • Hold the display with one hand while using your other hand to unplug the display power cable.
  2. iMac Intel 21.5" Retina 4K Display Display Assembly Cables Replacement: step 2, image 1 of 3 iMac Intel 21.5" Retina 4K Display Display Assembly Cables Replacement: step 2, image 2 of 3 iMac Intel 21.5" Retina 4K Display Display Assembly Cables Replacement: step 2, image 3 of 3
    • Continuing to support the display with one hand, flip up the metal retaining bracket on the display data cable.
    • Carefully pull the display data cable from its socket on the logic board.
    • Be sure to pull the display data cable connector straight out of its socket, keeping it parallel to the motherboard, to avoid damaging it.
Evan Noronha
223,648 Reputation
168 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 399
