iMac Intel 21.5" Retina 4K Display (2017) Logic Board Assembly Replacement
  1. iMac Intel 21.5" Retina 4K Display (2017) Logic Board Assembly Replacement, Logic Board Assembly: step 1, image 1 of 2 iMac Intel 21.5" Retina 4K Display (2017) Logic Board Assembly Replacement, Logic Board Assembly: step 1, image 2 of 2
    • Gently pull the left speaker cable straight out of its socket on the logic board.
  2. iMac Intel 21.5" Retina 4K Display (2017) Logic Board Assembly Replacement: step 2, image 1 of 1
    • De-route the left speaker cable by pulling it straight up out of the retaining clip in the back of the rear enclosure.
  3. iMac Intel 21.5" Retina 4K Display (2017) Logic Board Assembly Replacement: step 3, image 1 of 2 iMac Intel 21.5" Retina 4K Display (2017) Logic Board Assembly Replacement: step 3, image 2 of 2
    • Similarly to the previous step, de-route the SATA and power cables by pulling the braid straight up out of the retaining clip.
  4. iMac Intel 21.5" Retina 4K Display (2017) Logic Board Assembly Replacement: step 4, image 1 of 2 iMac Intel 21.5" Retina 4K Display (2017) Logic Board Assembly Replacement: step 4, image 2 of 2
    • Peel up the piece of tape connecting the left speaker connector to the SATA power and data cables.
  5. iMac Intel 21.5" Retina 4K Display (2017) Logic Board Assembly Replacement: step 5, image 1 of 3 iMac Intel 21.5" Retina 4K Display (2017) Logic Board Assembly Replacement: step 5, image 2 of 3 iMac Intel 21.5" Retina 4K Display (2017) Logic Board Assembly Replacement: step 5, image 3 of 3
    • Flip up the metal retaining bracket on the FaceTime camera cable connector.
    • Pull the FaceTime camera cable straight out of its socket on the logic board.
    • This is a delicate connector that can be easily damaged.
  6. iMac Intel 21.5" Retina 4K Display (2017) Logic Board Assembly Replacement: step 6, image 1 of 1
    • Remove the two 4.0 mm T5 Torx screws securing the four antenna connectors to the AirPort/Bluetooth card.
  7. iMac Intel 21.5" Retina 4K Display (2017) Logic Board Assembly Replacement: step 7, image 1 of 3 iMac Intel 21.5" Retina 4K Display (2017) Logic Board Assembly Replacement: step 7, image 2 of 3 iMac Intel 21.5" Retina 4K Display (2017) Logic Board Assembly Replacement: step 7, image 3 of 3
    • Disconnect all four antenna connectors by prying them straight up from their sockets on the AirPort/Bluetooth card.
  8. iMac Intel 21.5" Retina 4K Display (2017) Logic Board Assembly Replacement: step 8, image 1 of 2 iMac Intel 21.5" Retina 4K Display (2017) Logic Board Assembly Replacement: step 8, image 2 of 2
    • Gently pull the right speaker cable connector straight down and out of its socket on the logic board.
  9. iMac Intel 21.5" Retina 4K Display (2017) Logic Board Assembly Replacement: step 9, image 1 of 3 iMac Intel 21.5" Retina 4K Display (2017) Logic Board Assembly Replacement: step 9, image 2 of 3 iMac Intel 21.5" Retina 4K Display (2017) Logic Board Assembly Replacement: step 9, image 3 of 3
    • Use the flat edge of a spudger to pry the headphone jack cable connector from its socket on the logic board.
    • Push the cable slightly to the right.
  10. iMac Intel 21.5" Retina 4K Display (2017) Logic Board Assembly Replacement: step 10, image 1 of 1
    • Peel off the tape covering the exhaust duct.
  11. iMac Intel 21.5" Retina 4K Display (2017) Logic Board Assembly Replacement: step 11, image 1 of 1
    • Remove the following T8 Torx screws securing the exhaust duct to the rear enclosure:
    • Two 6.2 mm screws
    • Two 4.7 mm screws
  12. iMac Intel 21.5" Retina 4K Display (2017) Logic Board Assembly Replacement: step 12, image 1 of 3 iMac Intel 21.5" Retina 4K Display (2017) Logic Board Assembly Replacement: step 12, image 2 of 3 iMac Intel 21.5" Retina 4K Display (2017) Logic Board Assembly Replacement: step 12, image 3 of 3
    • Use the tip of a spudger to flip open the retaining flap on the microphone ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Gently pull the microphone ribbon cable straight out of its socket.
  13. iMac Intel 21.5" Retina 4K Display (2017) Logic Board Assembly Replacement: step 13, image 1 of 1
    • Remove the four 7.3 mm T8 Torx screws securing the logic board to the rear enclosure.
  14. iMac Intel 21.5" Retina 4K Display (2017) Logic Board Assembly Replacement: step 14, image 1 of 3 iMac Intel 21.5" Retina 4K Display (2017) Logic Board Assembly Replacement: step 14, image 2 of 3 iMac Intel 21.5" Retina 4K Display (2017) Logic Board Assembly Replacement: step 14, image 3 of 3
    • Tilt the top of the logic board away from the rear enclosure.
    • As you tilt the logic board, pull the right speaker connector to the right and out of the way of the board.
    • Lift the logic board straight up and out of the iMac.
    • Be careful not to snag the board on any of the rear enclosure's screw posts.
Adam O'Camb
196,895 Reputation
416 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 11
All Time: 108
