iMac Intel 21.5" EMC 2805 Display Assembly Cables Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iMac Intel 21.5" EMC 2805 Display Assembly Cables Replacement, Display Assembly Cables: step 1, image 1 of 3 iMac Intel 21.5" EMC 2805 Display Assembly Cables Replacement, Display Assembly Cables: step 1, image 2 of 3 iMac Intel 21.5" EMC 2805 Display Assembly Cables Replacement, Display Assembly Cables: step 1, image 3 of 3
    • Use a pair of tweezers to flip up the metal retaining bracket on the display data cable.
    • Carefully pull the display data cable from its socket on the logic board.
    • Be sure to pull the display data cable connector straight out of its socket.
  2. iMac Intel 21.5" EMC 2805 Display Assembly Cables Replacement: step 2, image 1 of 2 iMac Intel 21.5" EMC 2805 Display Assembly Cables Replacement: step 2, image 2 of 2
    • While holding the display up with one hand, use the other hand to unplug the display power cable.
    • Lift the display up enough to have easy access to the connector, but not so much that you stretch the cables and stress their connections (about 8").
Walter Galan
694,782 Reputation
1,203 Guides authored
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 8
All Time: 90
