Replacing iMac Intel 21.5" EMC 2544 Heat Sink Assembly
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Replacing iMac Intel 21.5" EMC 2544 Heat Sink Assembly, Heat Sink Assembly: step 1, image 1 of 3 Replacing iMac Intel 21.5" EMC 2544 Heat Sink Assembly, Heat Sink Assembly: step 1, image 2 of 3 Replacing iMac Intel 21.5" EMC 2544 Heat Sink Assembly, Heat Sink Assembly: step 1, image 3 of 3
    • Disconnect and remove the SATA data and power cables from the logic board.
  2. Replacing iMac Intel 21.5" EMC 2544 Heat Sink Assembly: step 2, image 1 of 1
    • Remove the four 12 mm T10 shoulder screws from the spring plate behind the CPU.
  3. Replacing iMac Intel 21.5" EMC 2544 Heat Sink Assembly: step 3, image 1 of 1
    • Remove the spring plate from behind the CPU heat sink.
  4. Replacing iMac Intel 21.5" EMC 2544 Heat Sink Assembly: step 4, image 1 of 1
    • Lift and remove the backing plate from behind the CPU heat sink.
    • The backing plate has two posts that fit into alignment holes in the logic board and heat sink.
  5. Replacing iMac Intel 21.5" EMC 2544 Heat Sink Assembly: step 5, image 1 of 2 Replacing iMac Intel 21.5" EMC 2544 Heat Sink Assembly: step 5, image 2 of 2
    • Remove the three 12 mm T8 Torx screws securing the GPU heat sink to the logic board.
    • Remove the three springs left behind.
    • These springs might come up with the screws; be careful not to lose track of them.
  6. Replacing iMac Intel 21.5" EMC 2544 Heat Sink Assembly: step 6, image 1 of 2 Replacing iMac Intel 21.5" EMC 2544 Heat Sink Assembly: step 6, image 2 of 2
    • Lift and remove the heat sink up off the logic board.
    • The CPU will most likely detach with the heat sink, so be careful about where you lay it down.
Sam Goldheart
466,316 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,462 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 39
