iMac Intel 21.5" EMC 2544 Hard Drive Assembly Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iMac Intel 21.5" EMC 2544 Hard Drive Assembly Replacement, Hard Drive Assembly: step 1, image 1 of 3 iMac Intel 21.5" EMC 2544 Hard Drive Assembly Replacement, Hard Drive Assembly: step 1, image 2 of 3 iMac Intel 21.5" EMC 2544 Hard Drive Assembly Replacement, Hard Drive Assembly: step 1, image 3 of 3
    • Lift the hard drive from the edge nearest the fan and pull it slightly out of its recess.
    • The hard drive is attached by two cables, do not attempt to fully remove it from the iMac just yet.
  2. iMac Intel 21.5" EMC 2544 Hard Drive Assembly Replacement: step 2, image 1 of 2 iMac Intel 21.5" EMC 2544 Hard Drive Assembly Replacement: step 2, image 2 of 2
    • Disconnect the SATA power cable.
  3. iMac Intel 21.5" EMC 2544 Hard Drive Assembly Replacement: step 3, image 1 of 2 iMac Intel 21.5" EMC 2544 Hard Drive Assembly Replacement: step 3, image 2 of 2
    • Unplug the SATA data cable from the hard drive.
  4. iMac Intel 21.5" EMC 2544 Hard Drive Assembly Replacement: step 4, image 1 of 1
    • Lift and remove the hard drive from the iMac.
To reassemble your device, follow these instructions in reverse and use our Adhesive Strips Guide to reattach the display glass.
Sam Goldheart
465,854 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
135 Members
17,198 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 7
All Time: 123
