iMac Intel 21.5" EMC 2428 RAM Replacement
  1. iMac Intel 21.5" EMC 2428 RAM Replacement, Access Door: step 1, image 1 of 2 iMac Intel 21.5" EMC 2428 RAM Replacement, Access Door: step 1, image 2 of 2
    • Unplug your iMac's AC cord along with any peripheral devices.
    • Lay your iMac face-down on a soft, clean surface as shown.
    • Be sure there isn't any dirt or debris on your work surface, as it may scratch the glass panel on the front of your iMac. We recommend placing a towel between the iMac and the work surface.
    • Loosen the three Phillips screws securing the access door to the bottom edge of your iMac.
    • All three screws will remain captive in the access door.
    • Remove the access door.
  2. iMac Intel 21.5" EMC 2428 RAM Replacement, RAM: step 2, image 1 of 3 iMac Intel 21.5" EMC 2428 RAM Replacement, RAM: step 2, image 2 of 3 iMac Intel 21.5" EMC 2428 RAM Replacement, RAM: step 2, image 3 of 3
    • Gently slide the black plastic RAM pull tab out from the RAM slot.
    • Pull the black plastic tab away from the bottom edge of the iMac to eject the module(s) on that side of the RAM bay.
    • This may require a bit of force.
  3. iMac Intel 21.5" EMC 2428 RAM Replacement: step 3, image 1 of 1
    • Slide the old RAM module(s) out of their slots in the RAM bay and set them aside.
  4. iMac Intel 21.5" EMC 2428 RAM Replacement: step 4, image 1 of 3 iMac Intel 21.5" EMC 2428 RAM Replacement: step 4, image 2 of 3 iMac Intel 21.5" EMC 2428 RAM Replacement: step 4, image 3 of 3
    • Repeat the process in the previous steps to remove the RAM module(s) from the other side of the RAM bay.
  5. iMac Intel 21.5" EMC 2428 RAM Replacement: step 5, image 1 of 3 iMac Intel 21.5" EMC 2428 RAM Replacement: step 5, image 2 of 3 iMac Intel 21.5" EMC 2428 RAM Replacement: step 5, image 3 of 3
    • When installing new RAM modules, it is important to orient them correctly.
    • Be sure the small notch cut into each RAM module (shown in the first picture) mates with the protrusion in each RAM slot (shown in the second picture).
    • Your iMac has four RAM slots. Be sure to slide each RAM module into its slot horizontally. This will prevent getting the modules stuck between two of the adjacent slots.
    • Once you have oriented the new RAM modules correctly, gently slide them completely into the iMac and use your thumbs to firmly seat them in their sockets.
Past 24 Hours: 14
Past 7 Days: 81
Past 30 Days: 292
All Time: 90,897
