iMac Intel 21.5" EMC 2428 Optical Drive Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iMac Intel 21.5" EMC 2428 Optical Drive Replacement, Optical Drive: step 1, image 1 of 1
    • From here, the repair will be easier if you flip the computer around so the base is facing you.
    • Remove the following four screws:
    • One 9.3 mm T10 Torx screw with a large head
    • Three 9.3 mm T10 Torx screws with a normal sized head
  2. iMac Intel 21.5" EMC 2428 Optical Drive Replacement: step 2, image 1 of 2 iMac Intel 21.5" EMC 2428 Optical Drive Replacement: step 2, image 2 of 2
    • Pull the optical drive thermal sensor connector straight up from its socket on the logic board. Pull parallel to the board.
  3. iMac Intel 21.5" EMC 2428 Optical Drive Replacement: step 3, image 1 of 2 iMac Intel 21.5" EMC 2428 Optical Drive Replacement: step 3, image 2 of 2
    • Lift the inner edge of the optical drive and maneuver its connector past the GPU frame attached to the logic board.
    • Carefully pull the optical drive off its mounting pins on the right side of the outer case to gain clearance for disconnecting the optical drive cable.
    • Allow the optical drive to hang down as you de-route the optical drive thermal sensor connector from behind the GPU heat sink.
  4. iMac Intel 21.5" EMC 2428 Optical Drive Replacement: step 4, image 1 of 1
    • Disconnect the optical drive cable by pulling its connector away from the optical drive.
    • Remove the optical drive from the iMac.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 309
