Introduction
Use this guide to replace a burned-out or noisy optical drive fan.
Tool used on this step:Heavy-Duty Suction Cups (Pair)$14.95
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Gently lift the glass panel perpendicular to the face of the LCD enough to clear the steel mounting pins attached along the underside of the top edge of the glass panel.
Pull the glass panel away from the lower edge of the iMac and carefully set it aside.
Pull the vertical sync cable connector out of its socket on the LED driver board near the top left corner of your iMac.
Rotate the display out of the outer case enough to disconnect the LED backlight power cable from the LED driver board.
Carefully pull the display toward the top edge of your iMac and lift it out of the outer case, minding any cables that may get caught.
Remove the following four screws:
One 9.3 mm T10 Torx screw with a large head
Three 9.3 mm T10 Torx screws with a normal sized head
Pull the optical drive thermal sensor connector toward the top edge of the iMac to disconnect it from its socket on the logic board.
Lift the inner edge of the optical drive and maneuver its connector past the GPU frame attached to the logic board.
Carefully pull the optical drive off its mounting pins on the right side of the outer case to gain clearance for disconnecting the optical drive cable.
Allow the optical drive to hang down as you de-route the optical drive thermal sensor connector from behind the GPU heat sink.
Disconnect the optical drive cable by pulling its connector away from the optical drive.
Remove the optical drive from the iMac.
Remove the single 13 mm T10 Torx screw securing the optical drive fan to the outer case.
