Installing iMac Intel 21.5" EMC 2389 CPU Fan
  1. Installing iMac Intel 21.5" EMC 2389 CPU Fan, Glass Panel: step 1, image 1 of 2 Installing iMac Intel 21.5" EMC 2389 CPU Fan, Glass Panel: step 1, image 2 of 2
    Tool used on this step:
    Heavy-Duty Suction Cups (Pair)
    $14.95
    Buy
    • Before beginning, unplug your iMac and lay it on a soft surface as shown.
    • Stick a suction cup near each of the two top corners of the glass panel.
    • To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
    • If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
  2. Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 2, image 1 of 2 Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 2, image 2 of 2
    • Gently lift the glass panel perpendicular to the face of the LCD enough to clear the steel mounting pins attached along the underside of the top edge of the glass panel.
    • Pull the glass panel away from the lower edge of the iMac and carefully set it aside.
    • During reinstallation, be sure to meticulously clean the inside of the glass panel and the face of the LCD as any dust or fingerprints trapped inside will be annoyingly visible when the machine is turned on.
  3. Installing iMac Intel 21.5" EMC 2389 CPU Fan, Display: step 3, image 1 of 3 Installing iMac Intel 21.5" EMC 2389 CPU Fan, Display: step 3, image 2 of 3 Installing iMac Intel 21.5" EMC 2389 CPU Fan, Display: step 3, image 3 of 3
    • Remove the eight 8 mm T10 Torx screws securing the display to the outer case.
    • The last two pictures are detail shots of each side of the display.
  4. Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 4, image 1 of 1
    • Slightly lift the top edge of the display out of the outer case.
    • Do not lift it too much. There are several cables attaching the display to the logic board.
  5. Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 5, image 1 of 2 Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 5, image 2 of 2
    • Pull the vertical sync cable connector out of its socket on the LED driver board near the top left corner of your iMac.
  6. Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 6, image 1 of 2 Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 6, image 2 of 2
    • Rotate the display out of the outer case enough to disconnect the LED backlight power cable from the LED driver board.
    • Disconnect the LED backlight power cable by depressing the locking mechanism while pulling the connector away from its socket (toward the bottom edge of the iMac).
  7. Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 7, image 1 of 2 Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 7, image 2 of 2
    • The display data cable plug has a wire lock. Disengage the plug's lock by rotating the plastic tab so that it points upward. (It is not a pull tab.)
    • Pull the display data cable straight out of its socket on the logic board.
    • Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
  8. Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 8, image 1 of 2 Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 8, image 2 of 2
    • Disconnect the LCD thermal sensor cable connector from its socket on the logic board.
    • If your fan is spinning full speed after completion, check this connection or the hard drive's thermal sensor cable.
  9. Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 9, image 1 of 1
    • Carefully pull the display toward the top edge of your iMac and lift it out of the outer case, minding any cables that may get caught.
  10. Installing iMac Intel 21.5" EMC 2389 CPU Fan, Optical Drive: step 10, image 1 of 1
    • Remove the following four screws:
    • One 9.3 mm T10 Torx screw with a large head
    • Three 9.3 mm T10 Torx screws with a normal sized head
  11. Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 11, image 1 of 2 Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 11, image 2 of 2
    • Pull the optical drive thermal sensor connector toward the top edge of the iMac to disconnect it from its socket on the logic board.
  12. Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 12, image 1 of 2 Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 12, image 2 of 2
    • Lift the inner edge of the optical drive and maneuver its connector past the GPU frame attached to the logic board.
    • Carefully pull the optical drive off its mounting pins on the right side of the outer case to gain clearance for disconnecting the optical drive cable.
    • Allow the optical drive to hang down as you de-route the optical drive thermal sensor connector from behind the GPU heat sink.
  13. Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 13, image 1 of 1
    • Disconnect the optical drive cable by pulling its connector away from the optical drive.
    • Remove the optical drive from the iMac.
    • Do not forget to also move the thermal sensor from the optical drive to the enclosure when you install the second hard drive.
  14. Installing iMac Intel 21.5" EMC 2389 CPU Fan, Optical Drive Fan: step 14, image 1 of 1
    • Remove the single 13 mm T10 Torx screw securing the optical drive fan to the outer case.
  15. Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 15, image 1 of 1
    • Pull the optical drive fan off the pins attached to the outer case.
  16. Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 16, image 1 of 1
    • Pull the optical drive fan connector out of its socket on the logic board.
    • Remove the optical drive fan from the iMac.
  17. Installing iMac Intel 21.5" EMC 2389 CPU Fan, Logic Board: step 17, image 1 of 1
    • In the proceeding steps, you will disconnect the following cables:
    • SD Board and microphone
    • Left/Right Speaker
    • Wi-Fi Antenna
    • Bluetooth/Ambient Light Sensor/Camera/Left Temperature Sensor, Hard Drive Temperature Sensor and Hard Drive Fan
    • CPU Fan/Ambient Temperature and Power Button
    • IR Sensor
  18. Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 18, image 1 of 1
    • Pull the microphone cable connector toward the top edge of the iMac to disconnect it from the logic board.
  19. Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 19, image 1 of 1
    • Pull the SD board cable out of its socket on the logic board.
  20. Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 20, image 1 of 2 Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 20, image 2 of 2
    • Disconnect the left speaker and right speaker cables by pulling their connectors toward the right side of the iMac.
  21. Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 21, image 1 of 2 Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 21, image 2 of 2
    • Use the flat end of a spudger to pry both AirPort antenna connectors up from their sockets on the AirPort board.
    • The gray antenna attaches to the socket on the left and the black antenna attaches to the socket on the right.
  22. Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 22, image 1 of 1
    • Disconnect the hard drive fan by pulling its connector toward the top edge of the iMac.
  23. Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 23, image 1 of 1
    • Pull the hard drive thermal sensor cable out of its socket and toward the top edge of the iMac to disconnect it from the logic board.
  24. Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 24, image 1 of 1
    • Use your thumbnails on both sides of the Bluetooth/ambient light sensor/camera/left temperature connector to push it toward the top edge of the iMac and out of its socket on the logic board.
  25. Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 25, image 1 of 3 Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 25, image 2 of 3 Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 25, image 3 of 3
    • Pull the CPU fan/ambient temperature sensor connector toward the bottom left edge of the iMac and out of its socket on the logic board.
    • Pull the power button connector toward the bottom left corner of the iMac to disconnect it from its socket on the logic board.
  26. Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 26, image 1 of 1
    • Remove the piece of tape covering the IR sensor cable.
  27. Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 27, image 1 of 1
    • Use your thumbs to push the IR sensor connector out of its socket and toward the top edge of the iMac.
  28. Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 28, image 1 of 1
    • Pull the IR sensor board up from behind the front face of the outer case.
    • Remove the IR sensor and set it aside.
  29. Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 29, image 1 of 1
    • Remove the following seven screws:
    • Two 7 mm T10 torx screws
    • One 30 mm T10 Torx screw
    • Two 25 mm T10 Torx screws
    • Two 21 mm T10 Torx screws
  30. Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 30, image 1 of 2 Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 30, image 2 of 2
    • Be careful not to touch any solder joints on the back of the power supply. Capacitors may be charged enough to give you a dangerous shock.
    • One 9.3 mm T10 coarse-threaded screw
    • One 25 mm T10 coarse-threaded screw
    • Two 22 mm fine-threaded screws
    • Pull the upper right and lower left corners of the power supply away from the rear case to dislodge the mounting posts attached to the power supply's corners.
  31. Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 31, image 1 of 2 Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 31, image 2 of 2
    • Carefully lift the power supply out of the outer case and rotate it to expose the cable lock as shown, minding the DC-out and AC-in cables still attaching it to the iMac.
    • Disconnect the DC-out cable by depressing the locking mechanism on the connector while you pull the connector away from its socket on the power supply.
    • Once the locking mechanism has cleared the socket, pull the DC-in connector away from the power supply.
  32. Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 32, image 1 of 1
    • Disconnect the AC-In cable by depressing the locking mechanism while pulling the connector away from its socket.
    • Remove the power supply from the outer case.
  33. Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 33, image 1 of 1
    • Remove the plastic wall that is installed directly to the right of the LED driver board.
  34. Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 34, image 1 of 1
    • Remove the plastic pressure wall installed next to the hard drive.
  35. Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 35, image 1 of 2 Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 35, image 2 of 2
    • Slightly pull the logic board away from the back of the outer case, then lift it upward to clear the lower front face of the outer case.
  36. Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 36, image 1 of 1
    • Disconnect the audio port cable by pulling its connector away from the front face of the logic board.
  37. Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 37, image 1 of 1
    • If present, peel off the tape securing the hard drive SATA cable to the logic board.
  38. Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 38, image 1 of 2 Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 38, image 2 of 2
    • Depress the locking mechanism and carefully pull the DC-In cable out of its socket on the back of the logic board.
  39. Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 39, image 1 of 1
    • Being careful not to damage the socket on the logic board, gently pull the hard drive SATA data cable straight out of its socket on the logic board.
    • Remove the logic board, minding any cables that may get caught.
    • When reinstalling the logic board, plug in a mini display port cable and a USB cable into the outer USB port before tightening the logic board screws to ensure proper alignment.
  40. Installing iMac Intel 21.5" EMC 2389 CPU Fan, CPU Fan: step 40, image 1 of 1
    • Remove the two 13 mm T10 Torx screws securing the CPU fan to the outer case.
  41. Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 41, image 1 of 1
    • Pull the CPU fan straight up from its mounting pin near the bottom edge of the iMac.
  42. Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 42, image 1 of 2 Installing iMac Intel 21.5" EMC 2389 CPU Fan: step 42, image 2 of 2
    • Being careful not to put too much strain on the left speaker cable, flip the CPU fan over to expose its bottom edge.
    • Use the flat end of a spudger to press down one side of the speaker cable retainer as you use your other hands to slide the speaker cables out of the retainer.
    • Remove the CPU fan from the iMac.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 27
All Time: 10,836
