Installing iMac Intel 21.5" EMC 2308 Optical Drive Fan
  1. Installing iMac Intel 21.5" EMC 2308 Optical Drive Fan, Glass Panel: step 1, image 1 of 2 Installing iMac Intel 21.5" EMC 2308 Optical Drive Fan, Glass Panel: step 1, image 2 of 2
    Tool used on this step:
    Heavy-Duty Suction Cups (Pair)
    $14.95
    Buy
    • Before beginning, unplug your iMac and lay it on a soft surface as shown.
    • Stick a suction cup near each of the two top corners of the glass panel.
    • To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
    • If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
  2. Installing iMac Intel 21.5" EMC 2308 Optical Drive Fan: step 2, image 1 of 2 Installing iMac Intel 21.5" EMC 2308 Optical Drive Fan: step 2, image 2 of 2
    • Gently lift the glass panel perpendicular to the face of the LCD enough to clear the steel mounting pins attached along the underside of the top edge of the glass panel.
    • Pull the glass panel away from the lower edge of the iMac and carefully set it aside.
    • During reinstallation, be sure to meticulously clean the inside of the glass panel and the face of the LCD as any dust or fingerprints trapped inside will be annoyingly visible when the machine is turned on.
  3. Installing iMac Intel 21.5" EMC 2308 Optical Drive Fan, Display: step 3, image 1 of 3 Installing iMac Intel 21.5" EMC 2308 Optical Drive Fan, Display: step 3, image 2 of 3 Installing iMac Intel 21.5" EMC 2308 Optical Drive Fan, Display: step 3, image 3 of 3
    • Remove the eight 8 mm T10 Torx screws securing the display to the outer case.
    • The last two pictures are detail shots of each side of the display.
  4. Installing iMac Intel 21.5" EMC 2308 Optical Drive Fan: step 4, image 1 of 1
    • Slightly lift the top edge of the display out of the outer case.
    • Do not lift it too much. There are several cables attaching the display to the logic board.
  5. Installing iMac Intel 21.5" EMC 2308 Optical Drive Fan: step 5, image 1 of 3 Installing iMac Intel 21.5" EMC 2308 Optical Drive Fan: step 5, image 2 of 3 Installing iMac Intel 21.5" EMC 2308 Optical Drive Fan: step 5, image 3 of 3
    • Pull the vertical sync ribbon cable out of its socket on the LED driver board near the top left corner of your iMac.
    • The vertical sync ribbon cable has a ZIF style end, but the socket has no lock or retaining flap. Simply pull the cable away from its socket toward the optical drive side of the iMac to disconnect it from the LED driver board.
  6. Installing iMac Intel 21.5" EMC 2308 Optical Drive Fan: step 6, image 1 of 3 Installing iMac Intel 21.5" EMC 2308 Optical Drive Fan: step 6, image 2 of 3 Installing iMac Intel 21.5" EMC 2308 Optical Drive Fan: step 6, image 3 of 3
    • Rotate the display out of the outer case enough to disconnect the LED backlight power cable from the LED driver board.
    • Disconnect the LED backlight power cable by depressing the locking mechanism while pulling the connector away from its socket (toward the bottom edge of the iMac).
  7. Installing iMac Intel 21.5" EMC 2308 Optical Drive Fan: step 7, image 1 of 1
    • Squeeze the two display data cable connector arms together to unlock it from its socket on the logic board.
    • Pull the display data cable connector away from its socket on the logic board.
    • Be careful when disconnecting and reconnecting this cable, as it is easily damaged.
  8. Installing iMac Intel 21.5" EMC 2308 Optical Drive Fan: step 8, image 1 of 1
    • Disconnect the LCD thermal sensor cable connector from its socket on the logic board.
    • If your fan is spinning full speed after completion, check this connection or the hard drive's thermal sensor cable.
  9. Installing iMac Intel 21.5" EMC 2308 Optical Drive Fan: step 9, image 1 of 1
    • Carefully pull the display toward the top edge of your iMac and lift it out of the outer case, minding any cables that may get caught.
  10. Installing iMac Intel 21.5" EMC 2308 Optical Drive Fan, Optical Drive: step 10, image 1 of 1
    • Pull the optical drive thermal sensor connector straight away from its socket on the logic board.
  11. Installing iMac Intel 21.5" EMC 2308 Optical Drive Fan: step 11, image 1 of 1
    • Remove the four 9 mm T10 Torx screws securing the optical drive to the outer case.
  12. Installing iMac Intel 21.5" EMC 2308 Optical Drive Fan: step 12, image 1 of 1
    • Lift the inner edge of the optical drive and maneuver its connector past the frame attached to the logic board.
    • Carefully pull the optical drive off its mounting pins on the edge of the outer case to gain clearance for disconnecting the optical drive cable.
  13. Installing iMac Intel 21.5" EMC 2308 Optical Drive Fan: step 13, image 1 of 1
    • Use the flat end of a spudger to help disconnect the optical drive cable.
  14. Installing iMac Intel 21.5" EMC 2308 Optical Drive Fan, Optical Drive Fan: step 14, image 1 of 1
    • Remove the single 13 mm T10 Torx screw securing the optical drive fan to the outer case.
  15. Installing iMac Intel 21.5" EMC 2308 Optical Drive Fan: step 15, image 1 of 1
    • Pull the optical drive off the pins attached to the outer case.
  16. Installing iMac Intel 21.5" EMC 2308 Optical Drive Fan: step 16, image 1 of 1
    • Pull the optical drive fan connector away from its socket on the logic board.
    • Remove the optical drive fan from the iMac.
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 20
All Time: 8,372
