Introduction
Replace a broken CPU fan to keep temperatures down.
Loosen the three Phillips screws securing the access door to the bottom edge of your iMac.
Remove the access door from your iMac.
Tool used on this step:Heavy-Duty Suction Cups (Pair)$14.95
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Gently lift the glass panel perpendicular to the face of the LCD enough to clear the steel mounting pins attached along the underside of the top edge of the glass panel.
Pull the glass panel away from the lower edge of the iMac and carefully set it aside.
Pull the vertical sync ribbon cable out of its socket on the LED driver board near the top left corner of your iMac.
Rotate the display out of the outer case enough to disconnect the LED backlight power cable from the LED driver board.
Squeeze the two display data cable connector arms together to unlock it from its socket on the logic board.
Pull the display data cable connector away from its socket on the logic board.
Carefully pull the display toward the top edge of your iMac and lift it out of the outer case, minding any cables that may get caught.
Remove the following four screws securing the power supply to the outer case:
Two 22.2 mm fine-thread T10 Torx
One 25 mm coarse-thread T10 Torx
One 9 mm coarse-thread T10 Torx
Carefully lift the power supply out of the outer case and rotate it to expose the cable lock as shown, minding the DC-Out cable still attaching it to the iMac.
Disconnect the DC-In cable by depressing the locking mechanism on the connector while you pull the connector away from its socket on the power supply.
Once the locking mechanism has cleared the socket, pull the DC-In connector away from the power supply.
Disconnect the AC-In cable by depressing the locking mechanism while pulling the connector away from its socket.
Remove the power supply from the outer case.
Pull the optical drive thermal sensor connector straight away from its socket on the logic board.
Lift the inner edge of the optical drive and maneuver its connector past the frame attached to the logic board.
Carefully pull the optical drive off its mounting pins on the edge of the outer case to gain clearance for disconnecting the optical drive cable.
Remove the single 13 mm T10 Torx screw securing the optical drive fan to the outer case.
Pull the optical drive fan connector away from its socket on the logic board.
Remove the optical drive fan from the iMac.
Pull the left and right speaker connectors toward the right side of the iMac to disconnect them from the logic board.
Disconnect the following cables by pulling their connectors toward the top edge of the iMac:
Camera cable
Hard drive thermal sensor
Hard drive fan
Microphone
Disconnect the following cables by pulling their connectors toward the right edge of the iMac:
Ambient temperature sensor
Bluetooth cable
Disconnect the CPU fan and power button by pulling their connectors toward the left edge of the iMac.
If present, remove the piece of tape covering the IR sensor connector.
Disconnect the IR sensor by pulling its connector toward the top edge of the iMac.
Remove the following six screws securing the logic board to the outer case:
Three 25 mm T10 Torx
Two 21.5 mm T10 Torx
One 7 mm T10 Torx
Remove the plastic ducts from the side of the LED driver board and the hard drive by pulling them away from the outer case.
Carefully pull the logic board slightly away from the outer case.
While holding the board away from the outer case, rotate the board back and forth while lifting up to release it from the outer case.
Now that the lower edge of the board is free from the outer case, rotate the logic board toward yourself to expose its rear face.
Carefully pull the optical drive connector away from its socket on the logic board.
Disconnect the DC-In cable from the logic board by simultaneously depressing the locking lever on the connector while pulling it away from its socket.
Remove the logic board from the outer case.
If present, remove the pieces of clear tape securing the ambient temperature sensor cable and the left speaker cable to the rear case.
Peel the cable retainer off the side of the CPU fan.
Remove the CPU fan from the outer case, minding any cables that may get caught.
Carefully remove the left speaker and ambient temperature sensor cables from the CPU fan cable retainer.
Use the flat end of a spudger to pry open the ambient temperature sensor retainer.
Remove the ambient temperature sensor from the CPU fan.
