Installing iMac Intel 21.5" CPU Fan
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Installing iMac Intel 21.5" CPU Fan, CPU Fan: step 1, image 1 of 1
    • If present, remove the pieces of clear tape securing the ambient temperature sensor cable and the left speaker cable to the rear case.
  2. Installing iMac Intel 21.5" CPU Fan: step 2, image 1 of 1
    • Remove the two 13 mm T10 Torx screws securing the CPU fan to the outer case.
  3. Installing iMac Intel 21.5" CPU Fan: step 3, image 1 of 1
    • Peel the cable retainer off the side of the CPU fan.
    • If the tape on the cable retainer loses adhesion, remove the existing foam tape and either use double-sided tape or glue to reattach it to the CPU fan.
    • Remove the CPU fan from the outer case, minding any cables that may get caught.
  4. Installing iMac Intel 21.5" CPU Fan: step 4, image 1 of 1
    • De-route the left speaker cable from the clips securing it to the outer case.
  5. Installing iMac Intel 21.5" CPU Fan: step 5, image 1 of 2 Installing iMac Intel 21.5" CPU Fan: step 5, image 2 of 2
    • Carefully remove the left speaker and ambient temperature sensor cables from the CPU fan cable retainer.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 2,766
