iMac Intel 20" EMC 2266 RAM Replacement
  1. iMac Intel 20" EMC 2266 RAM Replacement, Access Door: step 1, image 1 of 1
    • Lay your iMac front side down on a table with the lower edge facing yourself.
    • Loosen the single Phillips screw in the center of the access door.
    • This screw is captive in the access door.
    • Remove the access door from your iMac.
  2. iMac Intel 20" EMC 2266 RAM Replacement, RAM: step 2, image 1 of 2 iMac Intel 20" EMC 2266 RAM Replacement, RAM: step 2, image 2 of 2
    • Use the sharp end of a spudger to pull the black plastic RAM tabs out of the memory bay.
    • Pull the black plastic RAM tab away from your iMac to eject the RAM chip.
  3. iMac Intel 20" EMC 2266 RAM Replacement: step 3, image 1 of 1
    • Grab the RAM chip by its edges and pull it straight out of its slot.
    • If two RAM chips are installed, repeat this process for the other chip.
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 39
All Time: 37,658
