Introduction
Is your iMac's hard drive running a bit hot? Replace the hard drive fan and keep your hard drive cool.
Lay your iMac front side down on a table with the lower edge facing yourself.
Loosen the single Phillips screw in the center of the access door.
Remove the access door from your iMac.
Tool used on this step:Heavy-Duty Suction Cups (Pair)$14.95
Stick two suction cups to opposing corners of the glass panel.
Remove the following 12 screws securing the front bezel to the rear case:
Eight 13 mm T8 Torx.
Four 25 mm T8 Torx.
Gently lift the front bezel from its top edge off the rear case.
Once the top edge of the front bezel has cleared the rear case, rotate the front bezel toward the stand and lift it off the rear case.
Rotate the front bezel away from the rest of the device and lay it above the top edge of the iMac.
Pull the LCD temperature sensor connector straight up off its socket on the logic board.
(located at the top of the logic board on the 24")
Remove the single T10 Torx screw securing the right speaker to the rear case.
Disconnect the optical drive fan connector from the audio board by pulling it straight away from its socket.
Gently lift the hard drive fan off the plastic pins protruding from the lower case.
3 other people completed this guide.
