iMac Intel 17" Optical Drive Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iMac Intel 17" Optical Drive Replacement, Optical Drive: step 1, image 1 of 1
    • Remove the two 7 mm T10 Torx screws securing the optical drive clip to the logic board.
  2. iMac Intel 17" Optical Drive Replacement: step 2, image 1 of 1
    • Remove the optical drive clip.
  3. iMac Intel 17" Optical Drive Replacement: step 3, image 1 of 1
    • Pull the optical drive thermal sensor cable connector away from its socket on the logic board.
  4. iMac Intel 17" Optical Drive Replacement: step 4, image 1 of 2 iMac Intel 17" Optical Drive Replacement: step 4, image 2 of 2
    • Squeeze the two optical drive bracket ears together while pulling the drive toward yourself.
    • It may be helpful to hold the logic board down near the optical drive connector when pulling the drive toward yourself to avoid both components lifting together.
    • Pull the optical drive away from the side of the rear panel and remove it from the iMac.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 1,734
