Introduction
Keep temperatures down and replace that broken fan!
Lay the iMac display-side down on a flat surface (putting a cloth under the screen to protect it from bumps).
Loosen the three Phillips screws securing the rear panel to the iMac.
Lift the rear panel slightly near the bottom of the iMac.
Pull the rear panel toward yourself and remove it from the iMac.
Disconnect the right fan from the logic board by pulling its connector straight up.
Lift the fan near its outlet and rotate it toward yourself until its lower bracket clears the edge of the logic board.
Lift the fan out of the chassis.
