iMac G5 20" Model A1076 Rear Panel Replacement
  1. iMac G5 20" Model A1076 Rear Panel Replacement, Rear Panel: step 1, image 1 of 1
    • Lay the iMac display-side down on a flat surface.
    • Loosen the three Phillips screws securing the rear panel to the iMac.
    • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
  2. iMac G5 20" Model A1076 Rear Panel Replacement: step 2, image 1 of 2 iMac G5 20" Model A1076 Rear Panel Replacement: step 2, image 2 of 2
    • Lift the rear panel slightly near the bottom of the iMac.
    • Pull the rear panel toward yourself and remove it from the iMac.
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 35
All Time: 10,755
