Introduction
The ins and outs of replacing your DC to DC board.
Use your thumbs to press both RAM arms in past the front bezel for enough clearance to lift it off the rear case.
While holding the RAM arms in with your thumbs, lift the lower edge of the front bezel enough to clear the rear case.
Tool used on this step:Plastic Cards$2.99
Insert a plastic card up into the corner of the air vent slot at the top of the rear case.
Push the card toward the top of the iMac to release the front bezel latch.
Pull the front bezel away from the rear case.
Repeat this process for the other side of the front bezel.
Lay your iMac stand-side down on a table.
Lift the front bezel from its lower edge and rotate it away from the rest of your iMac, minding the RAM arms that may get caught.
Lay the front bezel above the rest of the iMac.
If necessary, remove the piece of kapton tape wrapped around the microphone and camera cables.
Remove the two 5 mm T6 Torx screws securing the display data cable to the logic board.
Using its attached black tab, pull the display data cable connector up off the logic board.
Remove the four recessed coarse-thread 7.5 mm T10 Torx screws securing the display to the rear case.
Lift the display from its lower edge and pull it toward yourself to peel it off the EMI shield attached to its top edge.
Pull the DC power cable connector away from its socket to disconnect it from the DC to DC board.
Pull the power supply cable connector away from its socket to disconnect it from the DC to DC board.
