Introduction
Keep those electrons flowing by replacing your broken power supply!
Lay the iMac display-side down on a flat surface.
Loosen the three Phillips screws securing the rear panel to the iMac.
Lift the rear panel slightly from the bottom edge of the iMac.
Pull the rear panel toward yourself and remove it from the iMac.
Rotate the center Phillips screw on the bottom of the iMac clockwise until the rear panel clamp contacts the edge of the case.
While depressing the connector lock, insert the flat end of a heavy duty spudger into the gap between the power supply connector and its socket.
Twist the heavy duty spudger to slightly separate the connector from its socket.
Grab the power supply from each side and rotate its top edge toward yourself until it clears the logic board.
Lift the power supply out of the midplane.
