Introduction
Use this guide to remove your display inverter.
Lay the iMac display-side down on a flat surface.
Loosen the three Phillips screws securing the rear panel to the iMac.
Lift the rear panel slightly from the bottom edge of the iMac.
Pull the rear panel toward yourself and remove it from the iMac.
Remove the three 8 mm brass Phillips screws securing the optical drive to the midplane.
Lift the optical drive near the connector to separate it from the logic board.
Lift the free end of the optical drive slightly, then pull it away from the edge of the rear case to clear the two plastic positioning pins.
Lift the optical drive out of your iMac.
Slide the inverter-to-display cable connector from under the metal clip on the midplane.
Disconnect the inverter-to-display cable connector by pulling it straight away from its socket.
Remove the single Phillips screw securing the inverter to the logic board.
Lift the inverter straight up off the pins on the logic board.
Disconnect the inverter cable from the logic board by pulling it straight up from its socket.
