iMac G4 17 800 MHz EMC 1936 PRAM Battery Replacement
  1. iMac G4 17 800 MHz EMC 1936 PRAM Battery Replacement, Bottom Plate: step 1, image 1 of 1
    • Unplug all the cables from the computer, including the power cable. Lay the computer face-down, supporting the neck and base with a soft cloth under the screen.
  2. iMac G4 17 800 MHz EMC 1936 PRAM Battery Replacement: step 2, image 1 of 1
    • Loosen the four Phillips #0 screws.
  3. iMac G4 17 800 MHz EMC 1936 PRAM Battery Replacement: step 3, image 1 of 1
    • Carefully remove the base access panel.
  4. iMac G4 17 800 MHz EMC 1936 PRAM Battery Replacement, Bottom Plate Housing: step 4, image 1 of 2 iMac G4 17 800 MHz EMC 1936 PRAM Battery Replacement, Bottom Plate Housing: step 4, image 2 of 2
    • Remove the four 25mm T-15 screws.
  5. iMac G4 17 800 MHz EMC 1936 PRAM Battery Replacement: step 5, image 1 of 2 iMac G4 17 800 MHz EMC 1936 PRAM Battery Replacement: step 5, image 2 of 2
    • Open the housing plate.
    • Be gentle with the wires still connected to the logic board so as not to ruin the cables.
    • A fixed plug connector between the logic board and upper unit will cause some resistance. Pull gently but firmly.
  6. iMac G4 17 800 MHz EMC 1936 PRAM Battery Replacement, PRAM Battery: step 6, image 1 of 2 iMac G4 17 800 MHz EMC 1936 PRAM Battery Replacement, PRAM Battery: step 6, image 2 of 2
    • Gently remove the battery from its holder using the plastic opening tool.
    • Insert new battery.
    • Clean and re-apply thermal paste to the heat sink areas circled in Yellow. See Step 15 in iMac G4 17" Model M9168LLA Hard Drive Replacement for better photos and description.
Justin
303 Reputation
3 Guides authored
Cal Poly, Team 21-22, Maness Fall 2011 Member of Cal Poly, Team 21-22, Maness Fall 2011
CPSU-MANESS-F11S21G22
4 Members
13 Guides authored
Past 24 Hours: 6
Past 7 Days: 32
Past 30 Days: 116
All Time: 11,498
