Installing iMac G4 15" 700 MHz EMC 1873 Optical Drive
  1. Installing iMac G4 15" 700 MHz EMC 1873 Optical Drive, Outer Base Plate: step 1, image 1 of 2 Installing iMac G4 15" 700 MHz EMC 1873 Optical Drive, Outer Base Plate: step 1, image 2 of 2
    • Place the computer monitor face down on a safe, harmless surface.
    • Using a Phillips #00 screw driver, remove the four 6.86 mm screws from the metal plate.
  2. Installing iMac G4 15" 700 MHz EMC 1873 Optical Drive: step 2, image 1 of 1
    • Remove the metal plate from bottom of the iMac G4.
    • The four screws do not completely separate from the metal plate.
  3. Installing iMac G4 15" 700 MHz EMC 1873 Optical Drive, AirPort Card: step 3, image 1 of 1
    • Use a spudger to lift and remove the AirPort's antenna connector.
    • This step is only applicable to iMacs that came with an AirPort card installed.
  4. Installing iMac G4 15" 700 MHz EMC 1873 Optical Drive, RAM DIMM: step 4, image 1 of 2 Installing iMac G4 15" 700 MHz EMC 1873 Optical Drive, RAM DIMM: step 4, image 2 of 2
    • Release the tabs on each side of the module by simultaneously pushing each tab away from the RAM.
    • These tabs lock the module in place and releasing them will cause the module to "pop" up.
    • Remove the RAM module from the iMac.
  5. Installing iMac G4 15" 700 MHz EMC 1873 Optical Drive, Removing the Lower Case: step 5, image 1 of 1
    • Remove the four 28.07mm Torx #15 screws from the lower case.
  6. Installing iMac G4 15" 700 MHz EMC 1873 Optical Drive: step 6, image 1 of 2 Installing iMac G4 15" 700 MHz EMC 1873 Optical Drive: step 6, image 2 of 2
    • Open the base by carefully pulling straight off, do not rotate the cover.
    • Open slowly to ensure that no cables are damaged or disconnected.
  7. Installing iMac G4 15" 700 MHz EMC 1873 Optical Drive: step 7, image 1 of 1
    • Squeeze the small black tab and wiggle gently to remove the colored power cable.
    • Do not pull directly on the colored wires.
    • Do not remove black grounding wire.
  8. Installing iMac G4 15" 700 MHz EMC 1873 Optical Drive: step 8, image 1 of 1
    • Grab both sides of the blue connector and firmly pull to remove it from the mother board.
    • Do not pull directly on the ribbon cable.
  9. Installing iMac G4 15" 700 MHz EMC 1873 Optical Drive, Optical Drive: step 9, image 1 of 2 Installing iMac G4 15" 700 MHz EMC 1873 Optical Drive, Optical Drive: step 9, image 2 of 2
    • Using a Torx #9 screw driver, remove the two 8.77mm screws holding the drive's shield onto your iMac G4.
    • Remove the drive shield from your iMac.
  10. Installing iMac G4 15" 700 MHz EMC 1873 Optical Drive: step 10, image 1 of 1
    • Using a Torx # 10 screw driver, remove the four 19.12mm screws that mount the optical drive.
  11. Installing iMac G4 15" 700 MHz EMC 1873 Optical Drive: step 11, image 1 of 1
    • Grasp the HD/Optical Drive bundle by the by the sides and gently wiggle it loose from the sides.
    • Ensure there are no wires passing over the top of the drive bundle when removing it, as it may unintentionally disconnect something.
  12. Installing iMac G4 15" 700 MHz EMC 1873 Optical Drive: step 12, image 1 of 1
    • Unplug the power source from the optical drive by pinching the plastic base of the connector and wiggling it gently.
    • Do not use excessive force, or pull on the wires directly, in order to unplug the connector from the drive.
  13. Installing iMac G4 15" 700 MHz EMC 1873 Optical Drive: step 13, image 1 of 1
    • Unplug the ribbon cable from the optical drive by grasping the plastic base of the connector and wiggling it gently.
    • Do not pull on the ribbon cable directly.
  14. Installing iMac G4 15" 700 MHz EMC 1873 Optical Drive: step 14, image 1 of 1
    • Remove the four 6.75mm Torx # 10 screws mounting the drive.
    • There are two screws on both sides of drive mount.
  15. Installing iMac G4 15" 700 MHz EMC 1873 Optical Drive: step 15, image 1 of 1
    • Slide the optical drive out from the metal support mounted to hard drive.
Ryan Kozak
1,747 Reputation
3 Guides authored
Cal Poly, Team 5-32, Amido Fall 2011 Member of Cal Poly, Team 5-32, Amido Fall 2011
CPSU-AMIDO-F11S5G32
4 Members
11 Guides authored
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 93
All Time: 10,900
