iMac 27" 2017 Display Assembly Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iMac 27" 2017 Display Assembly Replacement, Install the service wedge: step 1, image 1 of 1
    Tool used on this step:
    iMac Intel 27" Cardboard Service Wedge
    Buy
  2. iMac 27" 2017 Display Assembly Replacement, Insert an opening tool: step 2, image 1 of 3 iMac 27" 2017 Display Assembly Replacement, Insert an opening tool: step 2, image 2 of 3 iMac 27" 2017 Display Assembly Replacement, Insert an opening tool: step 2, image 3 of 3
    • Starting on the left of the display, near the power button, insert the iMac Opening Tool into the gap between the glass panel and the rear case.
    • The hub on the iMac Opening Tool will keep you from pushing the wheel in too far. If using a different tool, insert it no more than 3/8" (9.5 mm) into the display. You risk severing antenna cables and causing serious damage if you insert the tool too far.
  3. iMac 27" 2017 Display Assembly Replacement, Slice through the display adhesive: step 3, image 1 of 3 iMac 27" 2017 Display Assembly Replacement, Slice through the display adhesive: step 3, image 2 of 3 iMac 27" 2017 Display Assembly Replacement, Slice through the display adhesive: step 3, image 3 of 3
    • Use the tool like a pizza cutter—roll it along through the gap, and it will cut the foam adhesive through the center.
    • Be sure to always push with the handle behind the cutting wheel. If you pull, the wheel might get pulled out of the handle.
    • Run the tool up along the left side of the display.
  4. iMac 27" 2017 Display Assembly Replacement, Cut through the remaining adhesive: step 4, image 1 of 3 iMac 27" 2017 Display Assembly Replacement, Cut through the remaining adhesive: step 4, image 2 of 3 iMac 27" 2017 Display Assembly Replacement, Cut through the remaining adhesive: step 4, image 3 of 3
    • Continue wheeling the tool up around the top left corner.
  5. iMac 27" 2017 Display Assembly Replacement: step 5, image 1 of 2 iMac 27" 2017 Display Assembly Replacement: step 5, image 2 of 2
    • Cut the adhesive along the top left of the display.
  6. iMac 27" 2017 Display Assembly Replacement: step 6, image 1 of 2 iMac 27" 2017 Display Assembly Replacement: step 6, image 2 of 2
    • Continue along the top of the display.
    • You may want to run the tool back and forth through what you've already cut a few times, to ensure you get as much of the adhesive separated as possible.
  7. iMac 27" 2017 Display Assembly Replacement: step 7, image 1 of 3 iMac 27" 2017 Display Assembly Replacement: step 7, image 2 of 3 iMac 27" 2017 Display Assembly Replacement: step 7, image 3 of 3
    • Push the tool around the top right corner of the display.
  8. iMac 27" 2017 Display Assembly Replacement: step 8, image 1 of 2 iMac 27" 2017 Display Assembly Replacement: step 8, image 2 of 2
    • Wheel the tool down along the right side of the display.
  9. iMac 27" 2017 Display Assembly Replacement: step 9, image 1 of 2 iMac 27" 2017 Display Assembly Replacement: step 9, image 2 of 2
    • Finish pushing the opening tool to the bottom of the right side of the display.
    • At this point, you'll want to run the tool back around the entire display, to ensure you cut as much adhesive as possible.
  10. iMac 27" 2017 Display Assembly Replacement, Separate the display: step 10, image 1 of 3 iMac 27" 2017 Display Assembly Replacement, Separate the display: step 10, image 2 of 3 iMac 27" 2017 Display Assembly Replacement, Separate the display: step 10, image 3 of 3
    Plastic Cards
    $2.99
    Buy
    • While the opening tool did the lion's share of the work, the display will still be slightly adhered to the case. A plastic card will be necessary to free up the last of this adhesive.
    • Set the iMac face-up on a table.
    • Starting from the top right corner of the iMac, insert a plastic card between the display and frame.
    • Be careful not to insert it more than 3/8" (9.5 mm), or you may damage internal components.
  11. iMac 27" 2017 Display Assembly Replacement: step 11, image 1 of 2 iMac 27" 2017 Display Assembly Replacement: step 11, image 2 of 2
    • Gently twist the plastic card to open the space between the display and frame, and cut any remaining adhesive near the corner.
    • Using too much force will crack the glass. Work carefully, and don't try to create a gap any larger than about 1/4" (6 mm).
  12. iMac 27" 2017 Display Assembly Replacement: step 12, image 1 of 3 iMac 27" 2017 Display Assembly Replacement: step 12, image 2 of 3 iMac 27" 2017 Display Assembly Replacement: step 12, image 3 of 3
    • Be sure to stop cutting before the iSight camera in this step, or you may damage it.
    • Slide the card toward the center of the display, to cut any remaining adhesive.
  13. iMac 27" 2017 Display Assembly Replacement: step 13, image 1 of 2 iMac 27" 2017 Display Assembly Replacement: step 13, image 2 of 2
    • Put the card into the corner again and let it stay there to keep the adhesive from resettling.
  14. iMac 27" 2017 Display Assembly Replacement: step 14, image 1 of 3 iMac 27" 2017 Display Assembly Replacement: step 14, image 2 of 3 iMac 27" 2017 Display Assembly Replacement: step 14, image 3 of 3
    • Insert a second card into the gap between the display and frame in the top left corner.
  15. iMac 27" 2017 Display Assembly Replacement: step 15, image 1 of 2 iMac 27" 2017 Display Assembly Replacement: step 15, image 2 of 2
    • Gently twist the card, slightly increasing the space between the display and frame.
    • As with the other side, move slowly to allow the adhesive to break, and be careful not to over-stress the display glass.
  16. iMac 27" 2017 Display Assembly Replacement: step 16, image 1 of 3 iMac 27" 2017 Display Assembly Replacement: step 16, image 2 of 3 iMac 27" 2017 Display Assembly Replacement: step 16, image 3 of 3
    • Slide the plastic card toward the center, again stopping just before the iSight camera.
  17. iMac 27" 2017 Display Assembly Replacement: step 17, image 1 of 2 iMac 27" 2017 Display Assembly Replacement: step 17, image 2 of 2
    • Insert the card back into the top left corner.
  18. iMac 27" 2017 Display Assembly Replacement: step 18, image 1 of 3 iMac 27" 2017 Display Assembly Replacement: step 18, image 2 of 3 iMac 27" 2017 Display Assembly Replacement: step 18, image 3 of 3
    • With the cards inserted as shown near the corners, gently twist the cards to increase the gap between display and case.
    • If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the adhesive in the problem area.
    • Begin to lift the top of the display up from the frame.
    • Only lift the display a few inches—it is still attached to the iMac by data and power cables.
  19. iMac 27" 2017 Display Assembly Replacement, Disconnect the display cables: step 19, image 1 of 2 iMac 27" 2017 Display Assembly Replacement, Disconnect the display cables: step 19, image 2 of 2
    • While holding the display up with one hand, use the other to unplug the display power cable.
    • Lift the display up enough to have easy access to the connections, but not so much that you stretch the cables and stress their connections (about 8").
  20. iMac 27" 2017 Display Assembly Replacement: step 20, image 1 of 3 iMac 27" 2017 Display Assembly Replacement: step 20, image 2 of 3 iMac 27" 2017 Display Assembly Replacement: step 20, image 3 of 3
    • Flip up the metal retaining bracket on the display data cable.
    • Disconnect the display data cable.
    • This is a delicate connection that can easily be broken. Be sure to pull the display data cable connector straight out of its socket, toward the top of the iMac.
  21. iMac 27" 2017 Display Assembly Replacement, Lift the display: step 21, image 1 of 2 iMac 27" 2017 Display Assembly Replacement, Lift the display: step 21, image 2 of 2
    • Lift the display up to a near-vertical position.
    • At this point there is still a strip of adhesive along the bottom of the display that will hold the display to the frame like a hinge. You can loosen this adhesive by working the display up and down a few times.
  22. iMac 27" 2017 Display Assembly Replacement, Remove the remaining adhesive: step 22, image 1 of 3 iMac 27" 2017 Display Assembly Replacement, Remove the remaining adhesive: step 22, image 2 of 3 iMac 27" 2017 Display Assembly Replacement, Remove the remaining adhesive: step 22, image 3 of 3
    • Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply (boxed in red).
    • Grasp the small tab at the end of one of the bottom edge display adhesive strips and pull the adhesive toward the top of the iMac to remove it.
    • Repeat this step with the other adhesive strip and remove it.
    • If either adhesive strip breaks before it's removed, use a plastic card to slice through the remaining adhesive.
  23. iMac 27" 2017 Display Assembly Replacement, Remove the display: step 23, image 1 of 3 iMac 27" 2017 Display Assembly Replacement, Remove the display: step 23, image 2 of 3 iMac 27" 2017 Display Assembly Replacement, Remove the display: step 23, image 3 of 3
    • Be very careful handling the display—it's big, heavy, and made of glass. The display has fragile edges. Avoid lifting the display by the corners.
    • Lift the display up from the frame and remove it from the iMac. Lay the display face down on a flat, soft surface.
    • It may be necessary to slowly lift from one side, to peel against the remaining adhesive.
    • After the adhesive is cut, it cannot be used to re-seal the display in place. Follow this guide when your repair is complete to replace the adhesive strips that secure the display to the rear enclosure.
Adam O'Camb
212,914 Reputation
416 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 523
