This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
Introduction
如果您正在使用iMac 27“2009年末或2010年机型来玩游戏,那么您可能希望将显卡升级到2011年型号的Radeon 6系列显卡。
Tool used on this step:Heavy-Duty Suction Cups (Pair)$14.95
将两个大吸力吸盘分别吸附在玻璃面板的左右上角。
然后将拉环扶住,接着抬起拉环,使之与另外一个拉环平行。(如图三)
[1]: 译者注:不必非使用蒸馏水,也可以使用饮用纯净水。
要极其小心显示屏的连接线,我已经把我的线给弄废了。
您需要移走硬盘的温度传感器线束再来移走显卡。
记住这条线缆的位置与顺序! ifixit提示:必须稍后重新安装到最近的SATA连接器以及黑色线缆必须朝向LCD
要重新组装您的设备,请按照本指南的相反顺序进行操作。
99 other people completed this guide.
Special thanks to these translators:
30%
These translators are helping us fix the world! Want to contribute?
Start translating ›
127 Comments
works perfectly ;-) just be slow and precised
Just be noticed that this upgrade not work for iMac 27 late 2009 equipped with core 2 duo CPU, but only with the i5 and i7 CPU one!
Paolo -
Did you know you can add an additional SSD drive WITHOUT needing to remove your Optical drive? It installs vertically just to the right of your HDD. I just performed this upgrade last weekend. I believe you can do this to 2009 and up models.
Regretfully Not on the iMac late 2009, because the motherboard has only 2 SATA ports, not 3 like the 2010 and later models...
Just a question: with this mod, are you able to use Airplay Mirroring in Mountain Lion? Since the inhability to use it on these macs is GPU-related, virtually with this Graphic card you may be able to enable it... Let me know please!!
