iMac 2019 Display Separation
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iMac 2019 Display Separation, Separate the display: step 1, image 1 of 2 iMac 2019 Display Separation, Separate the display: step 1, image 2 of 2
    • Lift the display up to a near-vertical position.
    • At this point there is still a strip of adhesive along the bottom of the display that will hold the display to the frame like a hinge. You can loosen this adhesive by working the display up and down a few times.
  2. iMac 2019 Display Separation: step 2, image 1 of 3 iMac 2019 Display Separation: step 2, image 2 of 3 iMac 2019 Display Separation: step 2, image 3 of 3
    • If necessary, a plastic card can be used to cut any remaining sections of the bottom adhesive strip.
  3. iMac 2019 Display Separation: step 3, image 1 of 3 iMac 2019 Display Separation: step 3, image 2 of 3 iMac 2019 Display Separation: step 3, image 3 of 3
    • Lift the display up from the frame and remove it from the iMac.
    • It may be necessary to slowly lift from one side to peel against the remaining adhesive.
    • Be very careful handling the display—it's big, heavy, and made of glass.
    • After the adhesive is cut, it cannot be used to re-seal the display in place. Follow this guide to replace the adhesive strips that secure the display to the rear enclosure.
Adam O'Camb
196,710 Reputation
416 Guides authored
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 9
All Time: 198
