Shop the Holiday Gift Guide
iHome iP41BR Top Buttons Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
20
Past 30 Days:
72
All Time:
466
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
Use this guide to replace the buttons (alarm, hour, minute, power, play/pause, and volume) on the top of the iHome.
Tools
    1. iHome iP41BR Top Buttons  Replacement, Remove Front Cover: step 1, image 1 of 1
      • Unplug your iHome before starting disassembly.
      • Unscrew the four 13mm Phillips #1 screws, located in the 4 indented holes on the back of the iHome.
      Ask FixBot
    2. iHome iP41BR Top Buttons  Replacement: step 2, image 1 of 1
      Tool used on this step:
      Buy
      • Pull front cover directly out and away from iHome base.
      • Pulling firmly should detach the cable on the bottom right. If not, use the tweezers to firmly pull the cable out of its socket.
      Ask FixBot
    3. iHome iP41BR Top Buttons  Replacement: step 3, image 1 of 1
      • Lay the front cover face down.
      • Pull the cover away from the housing gently to ensure no damage is done to the ribbon cable or the soldered connections.
      • Pinch the cable on the left and firmly pull it out of its socket.
      Ask FixBot
    4. iHome iP41BR Top Buttons  Replacement, Detach Speaker: step 4, image 1 of 1
      • Remove the four 10mm Phillips #1 screws located on either side of the speaker.
      Ask FixBot
    5. iHome iP41BR Top Buttons  Replacement: step 5, image 1 of 2 iHome iP41BR Top Buttons  Replacement: step 5, image 2 of 2
      • Pinching the speaker with your thumb and pointer finger, pull it firmly down and out, away from the housing.
      • If the speaker is difficult to pull out, push down on the buttons from the top to help loosen it.
      Ask FixBot
    6. iHome iP41BR Top Buttons  Replacement, Remove Buttons: step 6, image 1 of 1
      • Remove the four 8mm Phillips #0 screws from the top of the speaker.
      • Remove the two rows of buttons and replace.
      Ask FixBot
Author
with
Paige Reisman
201 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 72
All Time: 466
