iHome iH5 Charging dock Replacement
  1. iHome iH5 Charging dock Replacement, Charging dock: step 1, image 1 of 1
    • Remove the eight 5/16 inch screws with a #2 Phillips screwdriver.
  2. iHome iH5 Charging dock Replacement: step 2, image 1 of 1
    • Use tweezers to unplug the three wires connected to the circuit board. If the wires are tight pliers might work better.
  3. iHome iH5 Charging dock Replacement: step 3, image 1 of 1
    • Remove the five 5/16 inch screws from the circuit board.
  4. iHome iH5 Charging dock Replacement: step 4, image 1 of 2 iHome iH5 Charging dock Replacement: step 4, image 2 of 2
    • Flip the circuit board over.
    • There are capacitors all over the back side of the board. Be careful not to touch these capacitors (blue cylinders) as they can discharge—giving you a shock.
    • Unplug the eight wires attached to the circuit board with tweezers. If the wires are tight pliers might work better.
    • There is on wire in the orange box.
    • There are two wires in the yellow box.
    • There are five wires in the green box.
  5. iHome iH5 Charging dock Replacement: step 5, image 1 of 1
    • Remove the following four screws securing the iHome iH5 charging dock.
    • Use a #2 Phillips screwdriver to remove the four screws.
  6. iHome iH5 Charging dock Replacement: step 6, image 1 of 1
    • Gently remove the charging dock from the iHome iH5 by pulling it up.
  7. iHome iH5 Charging dock Replacement: step 7, image 1 of 1
    • Remove the final screws connecting the iH5 charging dock to the plastic holding platform
    • Use a #2 Phillips screwdriver to remove the 3/8 inch screws.
  8. iHome iH5 Charging dock Replacement: step 8, image 1 of 1
    • Replace the old iH5 charging dock with new iH5 charging dock.
Dustin Lamb
103 Reputation
1 Guide authored
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 15
All Time: 965
