Up to 20% off select tools
iFixit Side Stack Retail Display Assembly
View statistics:
Past 24 Hours:
Past 7 Days:
24
Past 30 Days:
86
All Time:
923
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 minutes - 1 hour
Difficulty: Moderate
    1. iFixit Side Stack Retail Display Assembly, Empty Box Components: step 1, image 1 of 1
      • Box should include:
      • Set of screws/driver
      • Metal rods
      • Honeycomb Base/Feet
      • Main stand (back/sides)
      • Two large, one small foldable shelf insert
      • Two large, one small black rectangular insert
      • "You can fix it" panel and iFixit topper (not pictured)
      Ask FixBot
    2. iFixit Side Stack Retail Display Assembly, Build Honeycomb Base: step 2, image 1 of 3 iFixit Side Stack Retail Display Assembly, Build Honeycomb Base: step 2, image 2 of 3 iFixit Side Stack Retail Display Assembly, Build Honeycomb Base: step 2, image 3 of 3
      • The three angled supports fit into the two rectangular supports.
      • Place the fully constructed honeycomb base into the display.
      Ask FixBot
    3. iFixit Side Stack Retail Display Assembly, "You can fix it": step 3, image 1 of 3 iFixit Side Stack Retail Display Assembly, "You can fix it": step 3, image 2 of 3 iFixit Side Stack Retail Display Assembly, "You can fix it": step 3, image 3 of 3
      • Fit “You can fix it” panel over front of honeycomb base
      • “You can fix it” panel sides fit INSIDE of base walls
      • Use screws to fasten
      Ask FixBot
    4. iFixit Side Stack Retail Display Assembly, Build Shelf Insert: step 4, image 1 of 3 iFixit Side Stack Retail Display Assembly, Build Shelf Insert: step 4, image 2 of 3 iFixit Side Stack Retail Display Assembly, Build Shelf Insert: step 4, image 3 of 3
      • Build bottom shelf, using one of two larger foldable shelves
      • Tabs fit together, fit side tabs along back, then fold over and secure
      Ask FixBot
    5. iFixit Side Stack Retail Display Assembly, Install Metal Supports: step 5, image 1 of 2 iFixit Side Stack Retail Display Assembly, Install Metal Supports: step 5, image 2 of 2
      • Install two metal support for middle shelf
      • Metal rods fit into provided holes
      Ask FixBot
    6. iFixit Side Stack Retail Display Assembly, Insert Bottom Shelf: step 6, image 1 of 3 iFixit Side Stack Retail Display Assembly, Insert Bottom Shelf: step 6, image 2 of 3 iFixit Side Stack Retail Display Assembly, Insert Bottom Shelf: step 6, image 3 of 3
      • Fit bottom shelf into bottom shelf slots cut into back of display
      • Tabs go out the back and then back in towards the front
      • Lay black shelf insert into shelf
      • Fit screws together to hold shelf in place
      • Repeat for middle and top shelves
      • Top shelf and insert are smaller than bottom and middle shelves
      Ask FixBot
    7. iFixit Side Stack Retail Display Assembly, Fold Sides into Honeycomb Base: step 7, image 1 of 1
      • Like so.
      • (Go Angels!)
      Ask FixBot
    8. iFixit Side Stack Retail Display Assembly, iFixt Header Sign: step 8, image 1 of 2 iFixit Side Stack Retail Display Assembly, iFixt Header Sign: step 8, image 2 of 2
      • Fold top section down to make holes match
      • Align iFixit sign and install using screws
      Ask FixBot
Author
with
Eric Essen
18,375 Reputation
9 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 24
Past 30 Days: 86
All Time: 923
