Installing iBook G4 14" 1.42 GHz DC-In Board
  1. Installing iBook G4 14" 1.42 GHz DC-In Board, Battery: step 1, image 1 of 2 Installing iBook G4 14" 1.42 GHz DC-In Board, Battery: step 1, image 2 of 2
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
  2. Installing iBook G4 14" 1.42 GHz DC-In Board, Lower Case: step 2, image 1 of 1
    • Close the display and flip the computer over.
    • Remove the three hex screws using a T8 Torx screwdriver.
    • The shorter screw is in the center.
  3. Installing iBook G4 14" 1.42 GHz DC-In Board: step 3, image 1 of 1
    • Use a spudger or small flathead screwdriver to remove the three rubber feet from the lower case.
  4. Installing iBook G4 14" 1.42 GHz DC-In Board: step 4, image 1 of 1
    • Remove the three newly-revealed Phillips screws.
    • One screw is underneath each bumper (three total).
  5. Installing iBook G4 14" 1.42 GHz DC-In Board: step 5, image 1 of 1
    • Use a spudger or small flathead screwdriver to pry up the three metal rings that housed the rubber bumpers.
  6. Installing iBook G4 14" 1.42 GHz DC-In Board: step 6, image 1 of 1
    • Remove the two Phillips screws on either side of the battery contacts.
  7. Installing iBook G4 14" 1.42 GHz DC-In Board: step 7, image 1 of 1
    • Breathe deeply. Trying times are ahead, but we promise the lower case does come off.
    • Push in the thin rims of the lower case surrounding the battery compartment, bending them past the tabs, and then lift up to free that corner of the lower case.
  8. Installing iBook G4 14" 1.42 GHz DC-In Board: step 8, image 1 of 1
    • There is a slot on the wall of the battery compartment that locks the lower case in place. Use a small flathead screwdriver to pry out the slot's lower rim and pull up on the lower case to free the slot from the tabs holding it.
  9. Installing iBook G4 14" 1.42 GHz DC-In Board: step 9, image 1 of 1
    • Run a spudger along the seam between the lower case and upper case on the front of the computer to free the tabs locking the lower case. Pull up on the lower case and continue to use the spudger as necessary until you hear three distinct clicks.
  10. Installing iBook G4 14" 1.42 GHz DC-In Board: step 10, image 1 of 1
    • Continue to run the spudger around the front, right corner. There are two tabs on the port side of the computer, one near the front corner and one near the sound-out port.
  11. Installing iBook G4 14" 1.42 GHz DC-In Board: step 11, image 1 of 1
    • There are three tabs over the optical drive that must be released before the lower case can come off. Slide the spudger into the lower case above the optical drive and run it toward the back of the computer until you hear three distinct clicks.
  12. Installing iBook G4 14" 1.42 GHz DC-In Board: step 12, image 1 of 1
    • The front and sides of the lower case are now free.
    • Turn the computer so that the back is facing you and pull the lower case up and toward you until the back tabs pop free.
    • It may be helpful to jiggle the case up and down.
  13. Installing iBook G4 14" 1.42 GHz DC-In Board: step 13, image 1 of 1
    • Remove the small greasy springs with white plastic caps from either side of the battery contacts.
  14. Installing iBook G4 14" 1.42 GHz DC-In Board, Bottom Shield: step 14, image 1 of 1
    • Remove the following 10 screws from the bottom shield:
    • Six 3 mm Phillips
    • Three 7.5 mm Phillips
    • One 14 mm Phillips
  15. Installing iBook G4 14" 1.42 GHz DC-In Board: step 15, image 1 of 1
    • Lift the bottom shield off.
  16. Installing iBook G4 14" 1.42 GHz DC-In Board, DC-In Board: step 16, image 1 of 1
    • Remove the single Phillips screw securing the DC-In board.
  17. Installing iBook G4 14" 1.42 GHz DC-In Board: step 17, image 1 of 1
    • Angle the DC-In board out of its compartment.
  18. Installing iBook G4 14" 1.42 GHz DC-In Board: step 18, image 1 of 1
    • Lift the DC-In cable from the adhesive attaching it to the logic board.
  19. Installing iBook G4 14" 1.42 GHz DC-In Board: step 19, image 1 of 1
    • Disconnect the DC-In cable from the logic board.
    • Wiggling the connector parallel to the surface of the logic board while applying slight tension may aid in removal.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 10
All Time: 20,552
