Installing iBook G4 12" 800 MHz-1.2 GHz Upper Case
  1. Installing iBook G4 12" 800 MHz-1.2 GHz Upper Case, Battery: step 1, image 1 of 1
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
  2. Installing iBook G4 12" 800 MHz-1.2 GHz Upper Case: step 2, image 1 of 1
    • Lift the battery out of the computer.
  3. Installing iBook G4 12" 800 MHz-1.2 GHz Upper Case, Lower Case: step 3, image 1 of 1
    • Use a pin (or anything you like) to remove the three rubber feet from the lower case.
  4. Installing iBook G4 12" 800 MHz-1.2 GHz Upper Case: step 4, image 1 of 1
    • Remove the three newly-revealed Phillips screws.
  5. Installing iBook G4 12" 800 MHz-1.2 GHz Upper Case: step 5, image 1 of 1
    • Use a spudger or small flathead screwdriver to pry up the three metal rings that housed the rubber bumpers.
  6. Installing iBook G4 12" 800 MHz-1.2 GHz Upper Case: step 6, image 1 of 1
    • Remove the three Torx screws using a T8 Torx screwdriver.
    • The shorter screw is in the center of the computer.
  7. Installing iBook G4 12" 800 MHz-1.2 GHz Upper Case: step 7, image 1 of 1
    • Remove the two Phillips screws on either side of the battery contacts.
  8. Installing iBook G4 12" 800 MHz-1.2 GHz Upper Case: step 8, image 1 of 1
    • Breathe deeply. Trying times are ahead, but we promise the lower case does come off.
    • Push the thin rims of the lower case surrounding the battery compartment in, bending them past the tabs, and then lift up to free that corner of the lower case.
  9. Installing iBook G4 12" 800 MHz-1.2 GHz Upper Case: step 9, image 1 of 1
    • There is a slot on the wall of the battery compartment that locks the lower case in place. Use a small flathead screwdriver to pry out the slot's lower rim and pull up on the lower case to free the slot from the tabs holding it.
  10. Installing iBook G4 12" 800 MHz-1.2 GHz Upper Case: step 10, image 1 of 1
    • Run a spudger along the seam between the lower case and upper case on the front of the computer to free the tabs locking the lower case. Pull up on the lower case and continue to use the spudger as necessary until you hear three distinct clicks.
  11. Installing iBook G4 12" 800 MHz-1.2 GHz Upper Case: step 11, image 1 of 1
    • Continue to run the spudger around the front, right corner. There are two tabs on the port side of the computer, one near the front corner and one near the sound-out port.
  12. Installing iBook G4 12" 800 MHz-1.2 GHz Upper Case: step 12, image 1 of 1
    • There are three tabs over the optical drive that must be released before the lower case can come off. Slide the spudger into the lower case above the optical drive and run it toward the back of the computer until you hear three distinct clicks.
  13. Installing iBook G4 12" 800 MHz-1.2 GHz Upper Case: step 13, image 1 of 1
    • Once the front and sides of the lower case are free, turn the computer so that the back is facing you and pull the lower case up and away from you until the back tabs pop free.
    • it may be helpful to jiggle the case up and down.
  14. Installing iBook G4 12" 800 MHz-1.2 GHz Upper Case: step 14, image 1 of 1
    • Remove the small greasy springs with white plastic caps from either side of the battery contacts.
  15. Installing iBook G4 12" 800 MHz-1.2 GHz Upper Case, Bottom Shield: step 15, image 1 of 1
    • Remove the 4 Phillips screws from the bottom shield.
    • The two longer screws are along the computer's edge, near the ports.
  16. Installing iBook G4 12" 800 MHz-1.2 GHz Upper Case: step 16, image 1 of 1
    • Lift the bottom shield off.
  17. Installing iBook G4 12" 800 MHz-1.2 GHz Upper Case, DC-In Board: step 17, image 1 of 1
    • Remove the two Phillips screws securing the DC-In board.
  18. Installing iBook G4 12" 800 MHz-1.2 GHz Upper Case: step 18, image 1 of 1
    • Disconnect the DC-In cable from the logic board.
  19. Installing iBook G4 12" 800 MHz-1.2 GHz Upper Case: step 19, image 1 of 1
    • Deroute the cable from around the optical drive, removing tape as necessary, and angle the DC-In board out of its compartment.
  20. Installing iBook G4 12" 800 MHz-1.2 GHz Upper Case, Upper Case: step 20, image 1 of 1
    • Remove the two Phillips screws from the battery compartment.
  21. Installing iBook G4 12" 800 MHz-1.2 GHz Upper Case: step 21, image 1 of 1
    • We recommend placing the computer on a slab of grey anti-static packing foam from this point on to prevent damaging the logic board.
    • Turn over the computer and open it.
    • Pry up the magnet covering a Phillips screw near the middle of the computer.
  22. Installing iBook G4 12" 800 MHz-1.2 GHz Upper Case: step 22, image 1 of 1
    • Remove the following 7 screws from the edges of the keyboard area.
    • Three 2 mm Phillips along the right edge.
    • One 4.5 mm Phillips underneath where the magnet was.
    • One 6 mm Phillips with a small head in the lower left corner.
    • Two 6 mm Phillips with large heads, one in the upper left corner and one in the middle
  23. Installing iBook G4 12" 800 MHz-1.2 GHz Upper Case: step 23, image 1 of 1
    • Before you can yank the upper case off, you must disconnect the trackpad connector, the blue and white power cable, and speaker cable as described in the next steps.
    • Lift the upper case from the right side and use a spudger or your finger to disconnect the trackpad connector hidden beneath the white plastic tab. Due to model variatons your trackpad connector may be different from the one pictured.
  24. Installing iBook G4 12" 800 MHz-1.2 GHz Upper Case: step 24, image 1 of 1
    • Carefully lift the upper case about half of an inch and move it so that you can access the power and speaker cables.
    • If the upper case is sticking, it may be necessary to free the tabs holding the upper case to the metal framework along the outer edge of the battery compartment.
  25. Installing iBook G4 12" 800 MHz-1.2 GHz Upper Case: step 25, image 1 of 1
    • The connectors at the ends of the cables are attached very firmly to the sockets on the logic board. Pulling directly on the cable will either separate the cable from its connector or the socket from the logic board.
    • Lift the upper case enough to disconnect the blue and white power cable from the logic board. Using your fingernails or a dental pick, carefully pry the connector from its socket. Make sure you're pulling only on the connector and not on the socket.
  26. Installing iBook G4 12" 800 MHz-1.2 GHz Upper Case: step 26, image 1 of 1
    • Lift the upper case off completely and disconnect the multicolored speaker cable from the logic board. As before, make sure you're pulling only on the connector and not on the socket.
    • Tip: the multi-coloured cable may be easier and less daunting to disconnect after removing the top heat shield. Prop the top case upright while removing the shield - the connector is then much more accessible.
Attached Documents
iRobot
1 Reputation
636 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 18
All Time: 14,374
