iBook G4 12" 1.33 GHz Optical Drive Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
0
Past 7 Days:
8
Past 30 Days:
27
All Time:
2,136
Comments: 58
58 comments on steps.
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Difficult
Prerequisite Only This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Upgrade or replace the DVD, combo or SuperDrive.
Tools
    1. iBook G4 12" 1.33 GHz Optical Drive Replacement, Battery: step 1, image 1 of 2 iBook G4 12" 1.33 GHz Optical Drive Replacement, Battery: step 1, image 2 of 2
      • Lay your iBook upside down on a flat surface.
      • Use a coin to rotate the battery locking screw 90 degrees clockwise.
      • Lift the battery out of the computer.
      Ask FixBot
    1. iBook G4 12" 1.33 GHz Optical Drive Replacement, Keyboard: step 2, image 1 of 2 iBook G4 12" 1.33 GHz Optical Drive Replacement, Keyboard: step 2, image 2 of 2
      • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
      • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
      • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
      Ask FixBot
    2. iBook G4 12" 1.33 GHz Optical Drive Replacement: step 3, image 1 of 1
      • Remove the four silver Phillips screws that secure the RAM shield.
      Ask FixBot
    3. iBook G4 12" 1.33 GHz Optical Drive Replacement: step 4, image 1 of 1
      • Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
      • Make sure that you reconnect the keyboard cable before replacing the RAM shield.
      Ask FixBot
    1. iBook G4 12" 1.33 GHz Optical Drive Replacement, Lower Case: step 5, image 1 of 1
      • Use a spudger or small flathead screwdriver to remove the three rubber feet from the lower case.
      Ask FixBot
    2. iBook G4 12" 1.33 GHz Optical Drive Replacement: step 6, image 1 of 1
      • Remove the three newly-revealed Phillips screws.
      Ask FixBot
    3. iBook G4 12" 1.33 GHz Optical Drive Replacement: step 7, image 1 of 1
      • Use a spudger or small flathead screwdriver to pry up the three metal rings that housed the rubber bumpers.
      Ask FixBot
    4. iBook G4 12" 1.33 GHz Optical Drive Replacement: step 8, image 1 of 1
      • Remove the three Torx screws using a T8 Torx screwdriver.
      • The shorter screw is in the center of the computer.
      Ask FixBot
    5. iBook G4 12" 1.33 GHz Optical Drive Replacement: step 9, image 1 of 1
      • Remove the two 4.5 mm Phillips screws on either sides of the battery contacts.
      Ask FixBot
    6. iBook G4 12" 1.33 GHz Optical Drive Replacement: step 10, image 1 of 1
      • Breathe deeply. Trying times are ahead, but we promise the lower case does come off.
      • Push the thin rims of the lower case surrounding the battery compartment in, bending them past the tabs, and then lift up to free that corner of the lower case.
      Ask FixBot
    7. iBook G4 12" 1.33 GHz Optical Drive Replacement: step 11, image 1 of 1
      • There is a slot on the wall of the battery compartment that locks the lower case in place. Use a small flathead screwdriver to pry out the slot's lower rim and pull up on the lower case to free the slot from the tabs holding it.
      Ask FixBot
    8. iBook G4 12" 1.33 GHz Optical Drive Replacement: step 12, image 1 of 1
      • Run a spudger along the seam between the lower case and upper case on the front of the computer to free the tabs locking the lower case. Pull up on the lower case and continue to use the spudger as necessary until you hear three distinct clicks.
      Ask FixBot
    9. iBook G4 12" 1.33 GHz Optical Drive Replacement: step 13, image 1 of 1
      • Continue to run the spudger around the front right corner. There are two tabs on the port side of the computer, one near the front corner and one near the sound-out port.
      Ask FixBot
    10. iBook G4 12" 1.33 GHz Optical Drive Replacement: step 14, image 1 of 1
      • There are three tabs over the optical drive that must be released before the lower case can come off. Slide the spudger into the lower case above the optical drive and run it toward the back of the computer until you hear three distinct clicks.
      Ask FixBot
    11. iBook G4 12" 1.33 GHz Optical Drive Replacement: step 15, image 1 of 1
      • The front and sides of the lower case are now free.
      • Turn the computer so that the back is facing you and pull the lower case up and toward you until the back tabs pop free.
      • It may be helpful to jiggle the case up and down.
      Ask FixBot
    12. iBook G4 12" 1.33 GHz Optical Drive Replacement: step 16, image 1 of 1
      • Remove the small greasy springs with white plastic caps from either side of the battery contacts.
      Ask FixBot
      • Have patience and follow the directions, the end result is up to you.
      Ask FixBot
    1. iBook G4 12" 1.33 GHz Optical Drive Replacement, Bottom Shield: step 18, image 1 of 1
      • Remove the following 4 screws from the bottom shield:
      • Two 3 mm Phillips.
      • Two 7.5 mm Phillips.
      Ask FixBot
    2. iBook G4 12" 1.33 GHz Optical Drive Replacement: step 19, image 1 of 1
      • Lift the bottom shield off.
      Ask FixBot
    1. iBook G4 12" 1.33 GHz Optical Drive Replacement, DC-In Board: step 20, image 1 of 1
      • Remove the two Phillips screws securing the DC-In board, removing tape as necessary.
      Ask FixBot
    2. iBook G4 12" 1.33 GHz Optical Drive Replacement: step 21, image 1 of 2 iBook G4 12" 1.33 GHz Optical Drive Replacement: step 21, image 2 of 2
      • Deroute the cable from around the optical drive, removing tape as necessary.
      • Disconnect the DC-In cable from the logic board and angle the DC-In board out of its compartment.
      Ask FixBot
    1. iBook G4 12" 1.33 GHz Optical Drive Replacement, Upper Case: step 22, image 1 of 1
      • Remove the two 3 mm Phillips screws inside the left edge of the battery tray.
      Ask FixBot
    2. iBook G4 12" 1.33 GHz Optical Drive Replacement: step 23, image 1 of 1
      • We recommend placing the computer on a soft cloth from this point on to prevent damaging the logic board.
      • Turn over the computer and open it.
      • Use the flat side of a flathead screwdriver to remove the small magnet covering a screw near the middle of the computer.
      • The shorter screw goes in the lower left corner.
      Ask FixBot
    3. iBook G4 12" 1.33 GHz Optical Drive Replacement: step 24, image 1 of 1
      • Remove the following 7 screws from the edges of the keyboard area.
      • Three 2 mm Phillips along the right edge.
      • One 4.5 mm Phillips underneath where the magnet was.
      • One 6 mm Phillips with a small head in the lower left corner.
      • Two 6 mm Phillips with large heads, one in the upper left corner and one in the middle.
      Ask FixBot
    4. iBook G4 12" 1.33 GHz Optical Drive Replacement: step 25, image 1 of 1
      • Before you can yank the upper case off, you must disconnect the trackpad connector, the blue and white power cable, and speaker cable as described in the next steps. Be especially careful with these cables; never pull directly on the cables, but use a spudger to pry up the connector directly.
      • Carefully lift the upper case slightly and move it toward the front of the computer to reveal the trackpad connector. Use a spudger or your finger to disconnect the trackpad connector hidden beneath the white plastic tab.
      • After disconnecting the track pad connector, carefully rotate the upper case away from you and rest it against the display.
      Ask FixBot
    5. iBook G4 12" 1.33 GHz Optical Drive Replacement: step 26, image 1 of 1
      • The connectors at the ends of the following cables are attached very firmly to the sockets on the logic board. Pulling directly on the cable will either separate the cable from its connector or the socket from the logic board.
      • Use the sharp end of a spudger to disconnect the speaker cable connector.
      Ask FixBot
    6. iBook G4 12" 1.33 GHz Optical Drive Replacement: step 27, image 1 of 2 iBook G4 12" 1.33 GHz Optical Drive Replacement: step 27, image 2 of 2
      • Using the sharp end of a spudger, disconnect the connector for the blue and white power cables. Again, be careful to pry up only on the connector.
      • It is very easy to break the connector from the board, so be careful.
      • The key is to apply force in two directions, down to keep the surface board connections intact, up to release the connector.
      • The upper case is now free and can be removed from the computer.
      Ask FixBot
    1. iBook G4 12" 1.33 GHz Optical Drive Replacement, Top Shield: step 28, image 1 of 1
      • Remove the fifteen 3 mm Phillips screws securing the top shield to the computer.
      • Remove the following 16 screws:
      • Thirteen 3 mm Phillips.
      • One 3 mm Phillips. (actual screw not present in image)
      • Two 4 mm Phillips.
      • Be sure to fit the screw near the left hinge through the loop in the display data cable, securing the cable to the upper case.
      Ask FixBot
    2. iBook G4 12" 1.33 GHz Optical Drive Replacement: step 29, image 1 of 1
      • Lift the top shield up from the right side, minding the upper left corner, which may catch on the metal framework.
      • When reassembling, make sure you pull the antenna cable all the way through the slot in the middle. It is extremely hard to pull it back through after the top shield is screwed back in.
      Ask FixBot
    1. iBook G4 12" 1.33 GHz Optical Drive Replacement, Optical Drive: step 30, image 1 of 1
      • Remove the following 4 screws:
      • One 3 mm Phillips in the channel between the optical drive and fan.
      • Two 6 mm Phillips from the upper and bottom end of the drive bezel.
      • One 6 mm Phillips with a collar from bracket extending from the lower left corner of the drive.
      Ask FixBot
    2. iBook G4 12" 1.33 GHz Optical Drive Replacement: step 31, image 1 of 1
      • Use a spudger to pry up the Reed Switch Board from the optical drive, removing tape as necessary.
      Ask FixBot
    3. iBook G4 12" 1.33 GHz Optical Drive Replacement: step 32, image 1 of 1
      • This is a diagram of the ribbon clamp connector you will disconnect in the next step.
      • 1) With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
      • 2) After disengaging the locking bar, slide the cable out of the connector.
      Ask FixBot
    4. iBook G4 12" 1.33 GHz Optical Drive Replacement: step 33, image 1 of 1
      • Release the optical drive ribbon clamp as described above. Slide the optical drive ribbon out of its connector.
      Ask FixBot
    5. iBook G4 12" 1.33 GHz Optical Drive Replacement: step 34, image 1 of 1
      • Lift the optical drive from the metal framework.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 27
All Time: 2,136
