Installing iBook G3 12" Rear Display Bezel
  1. Installing iBook G3 12" Rear Display Bezel, Battery: step 1, image 1 of 1
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
  2. Installing iBook G3 12" Rear Display Bezel, Rear Display Bezel: step 2, image 1 of 2 Installing iBook G3 12" Rear Display Bezel, Rear Display Bezel: step 2, image 2 of 2
    • Use a 1.5mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
    • If you don't have a 1.5mm hex driver, you can probably get these screws out with a T6 Torx screwdriver. However, if you use a T6 Torx driver you'll be more likely to strip the screws.
  3. Installing iBook G3 12" Rear Display Bezel: step 3, image 1 of 2 Installing iBook G3 12" Rear Display Bezel: step 3, image 2 of 2
    • Insert the flat end of a spudger perpendicular to the face of the display into the gap between the front and rear bezels near the upper left corner of the display.
    • Rotate the spudger away from the display to pry the rear bezel off the front bezel.
  4. Installing iBook G3 12" Rear Display Bezel: step 4, image 1 of 1
    • Run your spudger along the top edge of the front display bezel to evenly separate the two bezels.
  5. Installing iBook G3 12" Rear Display Bezel: step 5, image 1 of 2 Installing iBook G3 12" Rear Display Bezel: step 5, image 2 of 2
    • Working down from the upper left corner, use the flat end of a spudger to pry the rear bezel away from the left edge of the display.
  6. Installing iBook G3 12" Rear Display Bezel: step 6, image 1 of 1
    • Use the flat end of a spudger to pry the rear bezel away from the right edge of the display.
    • If necessary, pry along the bottom edge of the rear bezel to separate it from the display assembly.
  7. Installing iBook G3 12" Rear Display Bezel: step 7, image 1 of 1
    • Lift the rear bezel off the display assembly.
Attached Documents
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 18
All Time: 4,277
