Installing iBook G3 12" Airport
  1. Installing iBook G3 12" Airport, Battery: step 1, image 1 of 1
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
  2. Installing iBook G3 12" Airport, Airport: step 2, image 1 of 1
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
    • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
  3. Installing iBook G3 12" Airport: step 3, image 1 of 1
    • Push the wire clasp toward the Airport card and pull it up to free it from the RAM shield.
  4. Installing iBook G3 12" Airport: step 4, image 1 of 1
    • Grasp the clear plastic tab on the Airport card and pull toward the right.
  5. Installing iBook G3 12" Airport: step 5, image 1 of 1
    • Hold the Airport card in one hand and use your other hand to remove the antenna cable.
Attached Documents
iRobot
1 Reputation
636 Guides authored
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 23
All Time: 22,502
