Shop the Holiday Gift Guide
iBUYPOWER WA550B Solid-State Drive Replacement
Views: 3.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
12
Past 30 Days:
69
All Time:
3,350
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide is for an iBUYPOWER WA550B desktop computer.
Before using this guide, try to re-install Windows and see if the solid-state drive appears in the re-installation media. If you cannot find it, try going into the BIOS. If you are still unable to find it open up the case and ensure that the SATA power and data cables are plugged in. One last thing you can do is to replace the SATA power and data cables. If you are still unable to locate the solid-state drive, this will confirm that it needs to be replaced.
Before beginning, make sure that the computer is turned off and unplugged from a power source.
Tools
    1. iBUYPOWER WA550B Solid-State Drive Replacement, SSD: step 1, image 1 of 2 iBUYPOWER WA550B Solid-State Drive Replacement, SSD: step 1, image 2 of 2
      • Remove the 6mm thumbscrews for the side panels.
      • You should be able to use your index finger and thumb to remove the screws. You can also use the Phillips #0 Screwdriver.
      Ask FixBot
    2. iBUYPOWER WA550B Solid-State Drive Replacement: step 2, image 1 of 2 iBUYPOWER WA550B Solid-State Drive Replacement: step 2, image 2 of 2
      • Slide each side panel off.
      Ask FixBot
    3. iBUYPOWER WA550B Solid-State Drive Replacement: step 3, image 1 of 1
      • Remove both the SATA power and the SATA data cables from the SSD.
      Ask FixBot
    4. iBUYPOWER WA550B Solid-State Drive Replacement: step 4, image 1 of 1
      • Remove the SSD mounting bracket from the case of the computer.
      Ask FixBot
    5. iBUYPOWER WA550B Solid-State Drive Replacement: step 5, image 1 of 1
      • Use the Phillips #0 Screwdriver to remove the 9mm HDD screws from the SSD that are holding it to the hard drive case.
      Ask FixBot
    6. iBUYPOWER WA550B Solid-State Drive Replacement: step 6, image 1 of 1
      • Remove the broken SSD from the mounting bracket.
      Ask FixBot
    7. iBUYPOWER WA550B Solid-State Drive Replacement: step 7, image 1 of 1
      • Place the new SSD in the hard drive case, and line it up with the screw holes.
      Ask FixBot
You have now successfully replaced the SATA Solid-State Drive for your computer!
Author
with
Zachary Pendley
217 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 69
All Time: 3,350
