eufy Security SpaceView Monitor Screen Replacement
  1. eufy Security SpaceView Monitor Screen Replacement, Display Assembly: step 1, image 1 of 2 eufy Security SpaceView Monitor Screen Replacement, Display Assembly: step 1, image 2 of 2
    • Use an opening tool to press into the opening notches built into the lower portion of the display.
    • The sides of the display each have two notches, while the top has 3 notches, and the bottom has 4 respectively.
    • Using the given tools, ensure that the tool enters the space of the opening notches, and apply force downwards, prying that specific part up and away from the housing.
    • Repeat for all sides and notches, until the display is completely detached from the rest of the monitor.
    Ask FixBot
  2. eufy Security SpaceView Monitor Screen Replacement, Lift the display: step 2, image 1 of 1
    • Lift the display up and away from the housing.
    • Take care to not twist or pull on the ribbon connector.
    Ask FixBot
  3. eufy Security SpaceView Monitor Screen Replacement, Screen: step 3, image 1 of 1
    • Lay the display face down on a table, to expose the back of the screen.
    • Use Phillips #00 screwdriver to unscrew each of the six screws that hold the display in place.
    • There are two on each end of the display, and one on each of its longer sides.
    Ask FixBot
  4. eufy Security SpaceView Monitor Screen Replacement: step 4, image 1 of 2 eufy Security SpaceView Monitor Screen Replacement: step 4, image 2 of 2
    • Gently lift the display housing, and set it aside.
    • The housing is ready to have the new display installed.
    Ask FixBot
  5. eufy Security SpaceView Monitor Screen Replacement: step 5, image 1 of 1
    • Gently disconnect the ribbon connector from the motherboard, taking care not to damage it.
    Ask FixBot
ZFarley
422 Reputation
3 Guides authored
UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2023 Member of UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G5
3 Members
12 Guides authored
2 Guide Comments
Where do you get the replacement screen?
Ronald - Reply Share
Yes please, where do we get a replacement screen, does it come with a ribbon cable? What is the part number?
Laguna - Reply Share
Past 24 Hours: 3
Past 7 Days: 34
Past 30 Days: 170
All Time: 3,014
