Display Assembly
    • Pull straight up on the pull-tab that is attached to the display-feed flex cable to disconnect the cable from the system board.
    • Disconnect the antenna cable.
    • Close the display.
    • Turn the computer upside down with the back of the computer facing you.
    Ask FixBot
  1. Display Assembly, Remove the Screws: step 2, image 1 of 1
    • From the bottom of the computer, remove the two M2.5 x 8-mm screws labeled "D."
    Ask FixBot
  2. Display Assembly, Remove the Screws: step 3, image 1 of 2 Display Assembly, Remove the Screws: step 3, image 2 of 2
    • From the back of the computer, remove the two M2.5 x 8-mm screws labeled "D."
    Ask FixBot
  3. Display Assembly, Removing the Cables: step 4, image 1 of 1
    • Turn the computer right-side up and open the display.
    • Carefully remove the antenna cable and the display cables from their routing guides.
    Ask FixBot
  4. Display Assembly, Lifting the Display Assembly: step 5, image 1 of 1
    • NOTICE: Be careful not to damage the display switch when removing the display.
    • Lift the display assembly out of the computer base.
    Ask FixBot
Terrence15
80,125 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
2,003 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 35
All Time: 893
