Introduction
How to remove and replace the motor for bObi's main brushes.
Remove bObi's dustbin. Press the small latch on the back and it will pop out.
Uninstall the 2 screws close to bObi’s dustbin, plus 2 smaller screws above the main brushes.
To detach the brushes completely, unplug them from bObi.
The motor is on the bottom of the main brush attachment. Uninstall the four screws which secure it, then lift the motor out.
Remove the stabilizer attached to the motor’s end, closer to its circuit plug before pulling the whole piece out.
Slide the long metal end in first, through the second stabilizer, so the end fits inside the motor holder.
Place the stabilizer you removed previously on the new motor.
