Shop the Holiday Gift Guide
iPad 2 Wi-Fi EMC 2415 LCD Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
3
Past 30 Days:
13
All Time:
705
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Removing LCD assembly with front panel attached. Internal Prerequisite.
Tools
    1. iPad 2 Wi-Fi EMC 2415 LCD Replacement, LCD: step 1, image 1 of 1
      • Remove the four 2.0 mm Phillips screws securing the LCD to the rear case.
      Ask FixBot
    2. iPad 2 Wi-Fi EMC 2415 LCD Replacement: step 2, image 1 of 2 iPad 2 Wi-Fi EMC 2415 LCD Replacement: step 2, image 2 of 2
      • Lift the LCD from its long edge closest to the volume buttons and rotate it out of the rear case.
      • Lay the LCD on the front panel as seen in the second picture.
      Ask FixBot
    3. iPad 2 Wi-Fi EMC 2415 LCD Replacement: step 3, image 1 of 1
      • Use the edge of a plastic opening tool to flip up the metal retaining clip securing the display data cable to its socket on the logic board.
      Ask FixBot
    4. iPad 2 Wi-Fi EMC 2415 LCD Replacement: step 4, image 1 of 1
      • Pull the display data cable out of its socket on the logic board.
      • Do not lift upward on the display data cable connector as you disconnect it.
      Ask FixBot
    5. iPad 2 Wi-Fi EMC 2415 LCD Replacement: step 5, image 1 of 1
      • Remove the LCD assembly from the iPad 2.
      Ask FixBot
Author
with
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 13
All Time: 705
