Shop the Holiday Gift Guide
2012-2015 Honda Civic Key Battery Replacement
Views: 413K
View statistics:
Past 24 Hours:
62
Past 7 Days:
293
Past 30 Days:
1,293
All Time:
413,114
Comments: 32
5 comments on steps, 27 guide comments.
Go to guide comments
Completed: 22
22 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 - 3 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Use this guide to replace the key battery for a 2012-2015 Honda Civic.
Parts
Tools
  • Phillips #0 Screwdriver
    5
  • Spudger
    4.9
    1. 2012-2015 Honda Civic Key Battery Replacement, Unscrew battery cover: step 1, image 1 of 2 2012-2015 Honda Civic Key Battery Replacement, Unscrew battery cover: step 1, image 2 of 2
      • Lay the key down so that the Honda symbol is facing upward.
      • Use a Phillips #0 screwdriver to remove one screw.
      Ask FixBot
    2. 2012-2015 Honda Civic Key Battery Replacement, Pry the cover off: step 2, image 1 of 2 2012-2015 Honda Civic Key Battery Replacement, Pry the cover off: step 2, image 2 of 2
      • Insert the flat end of your spudger into the notch in the side of the key/remote.
      • Pry the key remote apart to remove the cover.
      Ask FixBot
    3. 2012-2015 Honda Civic Key Battery Replacement, Replace the battery: step 3, image 1 of 1
      • Before you remove the battery, note which side faces up (+ or -). You should install your replacement the same way.
      • Remove the battery.
      • Your key may contain either a CR1616 or CR1620 battery. In some cases, either type will work, but for the best results, replace it with the same kind of battery that originally came with your key.
      • Install your matching new battery in the same orientation as the original.
      Ask FixBot
    4. 2012-2015 Honda Civic Key Battery Replacement, Reassembly: step 4, image 1 of 1
      • Place the two halves of the remote cover back together.
      • Press the unlock or lock buttons to make sure the remote is working.
      • Place the screw into the hole and tighten with a Phillips #0 screwdriver.
      Ask FixBot
22 other people completed this guide.
monica
486 Reputation
1 Guide authored
Baylor, Team 5-7, Williams Spring 2015 Member of Baylor, Team 5-7, Williams Spring 2015
BU-WILLIAMS-S15S5G7
4 Members
24 Guides authored
27 Guide Comments
The original battery in my 2012 Honda Civic Key is a Panasonic CR1616, not a CR1620. I bought an Energizer CR1620, and it was too thick.
Harry - Reply Share
Thanks, Harry!
Michelle Henderson - Reply Share
This isn't the same key remote that I have for my 2015 Civic Si (Sedan). Mine is more square shaped and the key is removable from the inside of the device. It also has no apparent opening-point anywhere around it. The only spot I would consider a possible entry point would be where the key is removed.
Robert - Reply Share
Robert;
Yes, once the key is removed it is just a matter prying it apart from between the two ears that stick up from the center. A fairly thick flat-bladed screw driver will do it (i used the handle end of a tweezer that was handy). This takes a CR2032 battery, (3) volt, very commonly found. There are two little tabs holding it in, plus (+) side up. Just snap it all back together. Voila.
arlen
Arlen Kerbaugh - Reply Share
Thank you very helpful!!!
inakwana waka - Reply Share
Past 24 Hours: 62
Past 7 Days: 293
Past 30 Days: 1,293
All Time: 413,114
