Shop the Holiday Gift Guide
iPhone 4S Speaker Enclosure Assembly Replacement
Views: 2K
View statistics:
Past 24 Hours:
Past 7 Days:
2
Past 30 Days:
14
All Time:
1,962
Comments: 10
10 comments on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Prereq when logic board is removed.
Tools
    1. iPhone 4S Speaker Enclosure Assembly Replacement, Speaker Enclosure Assembly: step 1, image 1 of 1
      • Remove the two 2.4 mm Phillips screws from the sides of the speaker enclosure assembly.
      Ask FixBot
    2. iPhone 4S Speaker Enclosure Assembly Replacement: step 2, image 1 of 1
      • Remove the small plastic bracket that was installed under the screw closest to the dock connector cable.
      Ask FixBot
    3. iPhone 4S Speaker Enclosure Assembly Replacement: step 3, image 1 of 2 iPhone 4S Speaker Enclosure Assembly Replacement: step 3, image 2 of 2
      • Remove the speaker enclosure assembly from the iPhone.
      • Before reinstalling the speaker enclosure assembly's screws, be sure the Wi-Fi grounding fingers are installed below the lip in the iPhone's metal case as seen in the second picture.
      • Before reassembly, be sure to clean all metal-to-metal contact points between the grounding fingers of the Wi-Fi antenna and the case of the iPhone with a de-greaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to cause wireless interference issues.
      Ask FixBot
3 other people completed this guide.
Author
with
Walter Galan
711,950 Reputation
1,203 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 14
All Time: 1,962
