Shop the Holiday Gift Guide
iPhone 4S Dock Connector Cable Replacement
Views: 2.5K
View statistics:
Past 24 Hours:
0
Past 7 Days:
0
Past 30 Days:
12
All Time:
2,523
Comments: 15
14 comments on steps, 1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Internal prerequisite.
Tools
    1. iPhone 4S Dock Connector Cable Replacement, Dock Connector Cable: step 1, image 1 of 2 iPhone 4S Dock Connector Cable Replacement, Dock Connector Cable: step 1, image 2 of 2
      • Remove the following screws securing the dock connector cable cover to the logic board:
      • One 1.5 mm Phillips screw
      • One 1.2 mm Phillips screw
      • Remove the metal dock connector cable cover.
      Ask FixBot
    2. iPhone 4S Dock Connector Cable Replacement: step 2, image 1 of 1
      • Use the edge of a plastic opening tool to pry the dock cable up from its socket on the logic board.
      Ask FixBot
    3. iPhone 4S Dock Connector Cable Replacement: step 3, image 1 of 1
      • Peel the dock connector cable off the adhesive securing it to the logic board and the side of the speaker enclosure.
      Ask FixBot
    4. iPhone 4S Dock Connector Cable Replacement: step 4, image 1 of 2 iPhone 4S Dock Connector Cable Replacement: step 4, image 2 of 2
      • Use the edge of a plastic opening tool to pry the cellular antenna cable up from its socket on the logic board.
      • De-route the cellular antenna cable out from under the metal fingers attached to the logic board.
      Ask FixBot
3 other people completed this guide.
Author
with
Walter Galan
711,950 Reputation
1,203 Guides authored
1 Guide Comment
tres belle c'est manifique
nabiljemjami92 - Reply Share
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 2,523
